DAC kort fra ebay og bygging av kabinett
  • Hornlyd
    Musikkglad
    Jeg har tatt sjansen og kjøpt et ferdig montert DAC kort på eaby.
    Det kom på ca kr 900,-
    Har tenkt å bygge et kabinett som matcher MAE SET1 og montere kildevelger og en passiv attenuator. Helt enkelt :)
    Så får vi se om det er plug&play eller plug&pray ???
    http://cgi.ebay.com/ws/eBayISAPI.dl...1ISOPr4%3D&viewitem=&sspagename=STRK:MEWNX:IT
    Her er litt speccer i tilfelle web linken skulle forsvinne:
    Upsampling 24bit/192 DAC KIT,TOROID TRAN,with USB input, HI END COMPONENTS CS4398, CS8416
    Up to this auction is a Upsampling 24bit/192 DAC KIT,TOROID TRAN,with USB input
    It has been fully tested and you only need to connect few wire and will enjoy a high End 24/192 DAC.
    It use famous Crystal chips : CS8416 as digital receiver and Burr Brown PCM1793 as DAC which perform 24/192 digital to analog translation .
    This new version can provide interchangeablity to other Hi End dac chips such as PCM1793, CS43122 , CS4397.....etc and other Hi End digital receiver other than CS8416.
    Upsampling chip CS8421 .
    Ideal for use with DVD, DVD Audio, CD, D-VHS, game console, and professional audio applications.
    Comes with a a IEC AC socket .
    Toroidal power transformer, worldwide AC voltage , 110V and 220V, complete separate digital and analog AC supply.
    5 separated individual precision voltage regulators to supply each individual need, good quality ELNA and WIMA capacitors from Germany to provide power source to the DAC. It can improve 3-D , stage , punch , and upper , lower frequency response
    United DAC PCB , high precision 1% DALE metal film resistors from USA ,
    CS8416 as digital receiver and as CS4398 which perform 24/192 digital to analog translation.
    Output stage use a DUAL-FET op-amp NE5532 for amplification . User can simply plug and upgrade to Hi End op-amp according to their musical preference but be careful with the direction of the op-amp location
    gold plated RCA sockets for analog ( right and left ) outputs and coaxial input.
    There is a jumper on the right corner of the DAC PCB for the selection of the input ( coaxial , optical). SA connected to DG is coaxial input and SA connected to 5V is the optical input.
    LED indicators on each individual power supply .
    PCB size: 132 x 175 x 50mm
    DC specification of the 24/192 DAC kit :
    INPUT DESCRIPTIONS
    DC voltage + 5V DC , +/-12V DC
    min.4.6V optimal 5V max.5.3V ; min.11.6V optimal 12V max.12.3V
    Temp. 20’C
    DC current normal 25ma max.35ma
    Temp. 20’C
    Electrical specification of the 24/192 DAC kit :
    FIGURE DESCRIPTIONS
    Input voltage Coaxial:
    min.0.3Vp-p normal 0.5Vp-p max.2Vp-p
    Signal/Noise Ratio normal 88dB max.90Db
    40kHz Lpf ON
    Separation Normal 90 dB
    1kHz 1Vp-p
    Dynamic range 96dB
    Analog output min.1Vp-p normal 1.5Vp-p max.2Vp-p
    Ro=600 ohm
    Hornlyd
    Musikkglad
    Det lille kortet kan/skal?? stikkes ned på høykant men da må noen jumpere fjernes
    Cobra2
    Gratulerer med ny DAC, verd akkurat hva du betalte (- frakt)
    Har testet & moddet noen tilsvarende selv...
    Arne K
    Nikko03
    ligner veldig på den gigaworks dac'en jeg kjøpte i fjor
    Jeg er veldig fornøyd med min dac her har det iallefall vært plug&play :)
    Proffen
    Bæææærgen
    Likner på min gigaworks også, og de funker som bare juling.
    Kan være litt å hente på å oppgradere op-ampene her....
    Proffen
    Proffen
    Bæææærgen
    PS: Kunne igrunnen vært interessant å høre HVOR bra folket mener disse dacene er, sammenliknet med dac`er en kan kjøpe ferdig sammenskrudd og med kjente merkenavn på...
    Noen som tar utfordringen?
    Proffen
    ee
    Spennende å følge med, jeg skal selv forsøke meg på en gigawork. vurderte du disse opp mot hverandre de ser jo veldig like ut?
    mvh ee
    mixture
    Jeg har en Gigawork DAC, men med DIR-9001 chip.
    Kjører nå med diskrete opamper fra Audio GD.
    Vesentlig løft å bytte ut NE5532 opampene med LM4562 eller diskrete opamper.
    Er godt fornøyd, og jeg synes Gigawork spiller veldig bra til prisen.
    Mixture
    Cobra2
    Ja, en rør/analog-utgang som koster dobbelt så mye som selve dac-kortet...+ trafo...
    Arne K
    FAB
    åssen har dere løst bytting mellom coax, optisk og usb på gigawork dac'en? Synes det er en dårlig løsning med den jumperen. Er ute etter et nytt kort, da jeg klarte knekke det andre ved å lodde på en bryter på pinnene. Klarte ved et uhell og koble sammen noen feil pinner. Det tålte den ikke, og sluttet å funke. Den slår seg på. Men får ingen lyd på utg. Uansett hva jeg velger av inng kilde. Jævli irriterende. Hadde bare en av de funket så kunne jeg jo ihvertfall brukt den. Har noen et kort til overs så si ifra.
    Proffen
    Bæææærgen
    Enkelt! ;D
    Skippet alt unntatt coax, fordi en vel strengt tatt må inn på printet og switche på en "bryter" der for å kunne veksle mellom ulik tilkoblinger.
    Foretar i stedet switchingen via en Monarchy DIP....
    Proffen
    Nikko03
    Jeg har koblet på en on off on bryter og fjernet jumper'ene på kortet lodda ledningene rett på pinnene på kortet.
    fungerer helt greit her hos meg
    Proffen
    Bæææærgen
    smart!
    men så er det ikke meg som har mekket sammen min heller, da...... ;D
    hvor mange av inngangene har du da tilgang til, med bryteren påkoblet slik du har?
    Proffen
    FAB
    Kan du med en lettfattet forklaring fortelle hvem av pinnene som er koblet til?
    Og hvor på bryteren. Prøvde meg nemlig på det samme med lik bryter fra clas.
    Jeg sier bare, ikke koble feil pinner sammen. Da tar dacen kvelden/kortslutter?
    når den slås på/bryter feil pinner sammen.
    Nikko03
    Ved å ta vekk jumper'a på kortet å koble den slik. Fikk jeg usb coax og optisk til å virke. Håper tegningen er forståelig :)
    frans
    Er det noen som har trafokoblet DACen på analogsiden?
    Hornlyd
    Musikkglad
    Arne K
    Mener du at den ikke er verdt mer enn 900 kr?
    Kan jeg likegjerne kjøpe en billig usb dac ala project, abrahamsen etc?
    Cobra2
    Arne K
    Riktig!
    Arne K
    Hornlyd
    Musikkglad
    Det kan du vel ikke mene?
    Er et bittelite enkelt DAC kort i Project eller Abrahamsen på størrelse med et VISA-kort like bra som gigaworks proppfull med komponeneter?
    Nikko03
    Prøvde gigaworks dac'en opp mot cambridge dacmagic her hjemme. Med optisk kabel fra pc ,Asio4all ,flac filer , jolida rørforsterker og H6 klone ht. Og i mine ører vil jeg si de to var jevngode. så da var jeg fornøyd med kjøpet jeg :) :)
    yggdrasill
    Har en lignende DAC. I original utførelse var den noe bedre enn den innebygde DAC'en i en Squeezebox.
    Har imidlertid skiftet ut hele det analoge trinnet med B1 buffere (Nelson Pass) og opplevde en stor forbedring.
    Hornlyd
    Musikkglad
    Er det vanskelig/dyrt?
    Har du noen foto?
    yggdrasill
    Det er ikke spesielt vanskelig, men heller ikke rett fram. Selve inngrepet i DAC'en går ut på å fjerne koblingskondensatorene ut av DAC-chipen, samt å stjele strøm fra DAC'ens +/-12V. Kretskortet til bufferne har jeg etset selv. Selve kretsen er enkel og uten justeringer, så det er helt rett fram. Delene er rimelige(noen få hundre kroner).
    Her er en litt mer inngående beskrivelse: http://www.diyaudio.com/forums/pass-labs/152794-voltagedac-b1-output-buffer.html
    Har funnet og vedlagt et bilde.
    Trodde i utgangspunktet at jeg ikke trengte koblingskondensatorer, så de havnet utenfor kretskortet. Har laget en senere hvor jeg gjorde plass til kondensatorene på kretskortet.
    Hornlyd
    Musikkglad
    Takk. Skal bygge en slik Pass B1. Har allerede drøftet prosjektet med en kompis som kan etse kretskort :D
    Cobra2
    DIY_dude
    OSLO
    Jeg har ikke trafokoblet akkurat denne dacen, men min erfaring med trafo er at den begrenser dynamikken en god del. Lyden flyter ikke like lett, og det låter mer kunstig, mer forvrengt, sammenlignet med et diskret transistortrinn ala B1 presentert av yggdrasill her. Aldri mer trafoer på meg. :p
    Proffen
    Bæææærgen
    hel skrev:
    Tror du både skal være en kløpper med loddebolten OG ha godt loddeutstyr for å få til denne 100%.
    En del av sakene som skal loddes på plass er nok rimelig smått.....
    Men bevares, dac`en kan være god den.
    Og en får ofte VFM på ebay...
    Er i alle fall meget godt nøgd med min gigaworkdac, som kanskje ikke er verdt mer enn det jeg har betalt, men som spiller som noe som koster en del mer IMHO...
    Proffen
    Cobra2
    Proffen
    Kanskje fordi mange kommersielle DAC'er er for dyre... ;D
    Arne K
    Proffen
    Bæææærgen
    Cobra2 skrev:
    Proffen
    Arne K
    DET er en annen sak... ;D
    Men skal jo glatt innrømme at jeg hørte klar forskjell på min diy-dac og en seriøs Emmlabsdac, da de ble holdt opp mot hverandre...og sånn SKAL det vel være mtp priser...
    Proffen
    FAB
    Fikk denne Gigawork dac`en oppe å gå igjen med et nytt kort.
    Bruker også opa 627 i analogdelen. Noe som gjorde den litt mer mørklåtende :)
    http://cgi.ebay.com/Pair-Dual-Mono-...678?pt=LH_DefaultDomain_0&hash=item25629b7af6
    Har sammenlignet den med abrahamsen dac`en og adac`en
    og synes personlig at Gigawork er et hakk bedre på alle omeråder.
    På både usb fra pc og coax/optisk fra cd/dvd-spiller.
    Det jeg legger spesielt merke til er i bass-omerådet.
    Der er den vanvittig rå. Meget bra definert, med skikkelig slamm.
    (Beste dac`en jeg har hørt til nå i bass / dypbass omerådet)
    Den er dog noe laidback i mellomregisteret, og det kunne ha vært ennå litt
    mer luft i toppen. Men til prisen. Bevares.
