Resultater 1 til 19 av 19
Abonnér på denne tråden
  1. #1
    Moderator bambadoo's Avatar
    Oct 2002
    Tagget i
    2 Innlegg
    Klasse D er lite effektivt
    Nå er det Dette som gjelder.
    Bristol, UK, 5th Oct: Audium Semiconductor has launched an audio power amplifier IC which, at normal listening levels[1], is 20 times more efficient than competing devices, such as Class D[2] amplifiers, without compromising audio quality. The AS1001 operates from a nominal 1.5V power supply and delivers 100W peak power output. The amplifier is so efficient that battery-powered amplified loudspeakers can run for up to 10 months on a set of four ‘C’ batteries, playing for three hours per day, vastly reducing CO2 from power generation and pollution from battery production[3].
    I don't believe in system matching. If something is good, it's good. If it only sounds good under certain conditions, it is not good - it is incorrect. - Charles Hansen
  2. #2
    Æresmedlem Valentino's Avatar
    Apr 2008
    Tagget i
    2 Innlegg
    But does it have enough slam and PRAT?
    Vik fra meg, O kjetterske Vranglærere! Jeg hører forskjell på alt! Halleluja!
    Anleggstråd: Bipolare Valentinos drodleDipol
    Uncle Violet flew as a pilot and there ain't no pretty girls in France. Now he runs a tiny little bookie joint. They say he never keeps it in his pants
  3. #3
    Oct 2002
    Tagget i
    2 Innlegg
    Sannsynligvis 20X mer
  4. #4
    Hifi Freak
    Mar 2002
    Tagget i
    0 Innlegg
    Sitat Sitat fra Valentino
    Det er Vidar P som skal bekymre seg om dette, ikke du :P
    Players win, players loose, players prepare, players practise, players get hurt but players always get up. No matter what the outcome is, players play!
  5. #5
    Hifi Freak slowmotion's Avatar
    May 2009
    Tagget i
    0 Innlegg
    .... without compromising audio quality.
    Jassågitt ....
  6. #6
    Oblivion
    Guest
    Sitat Sitat fra slowmotion
    Jassågitt ....
    Hvis klasse D ikke ødelegger lyden kan vel ikke en "forbedret" og mer "effektiv" slektning være dårligere
  7. #7
    Hifi Freak Cobra2's Avatar
    Feb 2003
    Tagget i
    0 Innlegg
    Album
    Er det første april allerede?
    Arne K
    Of all the things I've lost, I miss my mind the most.
    For sale:
    http://www.hifisentralen.no/forumet/...ser&userid=701
  8. #8
    Oblivion
    Guest
    Sitat Sitat fra Cobra2
    Arne K
    Tja... Når jeg prøvde Tripath klasse T for noen år tilbake ble jeg positivt overrasket..
    Det var ikke det beste jeg har hørt og ikke High End, men i forhold til konsumentmarkedet var den bra..
    Slik er det vel med denne ny chipen også - beregnet for konsument og ikke High End..
  9. #9
    Feb 2003
    Tagget i
    0 Innlegg
    Album
    Hvordan får du 100W fra 1,5V?
    (= PC-høyttaler-beregning?)
    Arne K
    For sale:
  10. #10
    Hifi Freak totte's Avatar
    Apr 2007
    Tagget i
    0 Innlegg
    Arne K
    Enkelt, du trekker bare 70 ampere.
    Der andre ser problemer ser jeg håpløshet
    -Østland: SME10 drivverk og arm | Lyra argo i | Vacuum State SVP2 | Orelle CD100 | Grace m903 | Sennheiser HD800 | Stax SR4070 og SRM272II | Adam Classic Column mk3 Active
    -Vestland: PC | Audiolense XO | LynxTWO-B | Rane AC22 | DBX231 | 2*Hypex UcD400AD | 2*Consonance stereotrinn| 2*Bohlender Graebener RD75 | 2*DIY 15" Dayton
    -Kontor/reise: Sennheiser PX100 og Denon AH-D750 rett i laptop
  11. #11
    Feb 2003
    Tagget i
    0 Innlegg
    Album
    Jeg synes jeg ser 70A gjennom det kortet...
    Arne K ( = sveisebriller)
    For sale:
  12. #12
    Dec 2003
    Hamar
    Tagget i
    0 Innlegg
    100W peak power og energien er lagret i kondisene og man får 100W i flere ns?
    Eller er det bilstereowatt fra 70-tallet?
    Eller er det målt flere ganger og lagt sammen resultatet?
    Eller er det kreativ markedsføring?
    Feickert Blackbird platespiller / Kuzma 4 point arm med VdH Colibri XCP-HO og Kuzma 4 point 14" arm med Miyajima Madake
    Luxman EQ500 RIAA
    Marantz CD-7 og CD12 - Luxman DA06 DAC - Apple TV / iPhone X / iPad for trådløs streaming
    Luxman L509x forsterker
    Tannoy DC10A med Tannoy ST-100 diskanter og 2 stk JL Audio Fathom 113 subwoofere
  13. #13
    Bransjeaktør Snickers-is's Avatar
    Feb 2004
    Tagget i
    10 Innlegg
    Men jeg tror de største C-batteriene, altså de med størst kapasitet, har omkring 8000mAh. Det vil på 4 celler si det samme som 48Wh.
    På 10 mnd, har vi ca 300 dager, og 3 timer i døgnet betyr 900 timer.
    48Wh/900 timer gir en snitteffekt på 0,053W, når den spiller. La oss nå si at vi bruker 1/8-metoden der peak er 8xsnittet. Det funker på det meste av musikk. Da får vi en peak effekt på 0,43W RMS.
    La oss nå si at høyttaleren har normal følsomhet, for eksempel 87dB SPL @ 1W/1m. Vi lytter på 2 meters avstand (litt kort, men dette er jo en ghettoblastergreie så vidt jeg har forstått), med 2 høyttalere. Effekten fordeles på de to men den totale virkningsgraden øker med 3dB. På grunn av avstanden mister vi imidlertid 6dB. Vi står da igjen med 84dB peak. Dette forutsatt at den ikke bruker noen strøm idle OVER HODET.
    Jeg kan være med på at for noen vil 84dB peak, og 72dB nominelt være ok, men det har lite med hifi å gjøre etter min mening. Man er jo også rimelig langt unna de 100W som kretsen påstås å levere.
    Om den kan levere 100W avhenger vel bare av om den har spenningskonvertering.
    Forøvrig er jeg usikker på om en idle strøm på kanskje 0.5-1W på klasse D virkelig er et stort problem.
    Jeg driver Midgard Audio
    If you do not se the problem, you will not look for a solution.
  14. #14
    Apr 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra Oblivion
    Arne K
    Hvilke forsterker basert på Tripath var dette?
  15. #15
    Oblivion
    Guest
    Sitat Sitat fra FAB
    Arne K
    Hei,
    Jeg husker ikke, men det var @ivarlo som kjøpte inn noen stk.
    Senere kom Trends T ampene.
    Når disse fikk byttet kondensatorene i signalveien, montert inn noen kondensatorer på powerrailen og en JFET regulator med 0,8 volt spenningsdropp ble Trends rimelig bra. Og ble den kjørt fra batteri enda bedre.
  16. #16
    Oblivion
    Guest
    Arne K
    I følge produsenten gjøres det slik:
    The AS1001 architecture uses patented techniques to minimise both fixed power losses and output-dependant variable power losses. The modulation scheme uses low switching rates to minimise switching losses. Power rail switching means that the amplifier operates efficiently from a low voltage rail most of the time, with a DC-DC boost converter driving higher voltage transistors on extreme audio peaks.
  17. #17
    Hifi-entusiast
    Mar 2005
    Tagget i
    0 Innlegg
    Sitat Sitat fra Snickers-is
    Hallo!
    Har du ikke hørt om effektomformer!?
  18. #18
    Apr 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra FAB
    Arne K
    Hei,
    Du skulle prøvd amp5 fra 41hz med "high power-kit"
    http://www.41hz.com/shop/item.asp?catid=13&itemid=7
    Jeg fikk hakaslepp etter noen timers lodding.
    Trodde ikke det var mulig og få så mye, for så lite penger
    Lyden kan minne litt om Doxa 70 mkII signature,
    Ikke mye dårligere ihvertfall.
    Kjørte med 2stk amp5 for noen år siden.
    Tror ikke trends kan hamle opp med de.
    P.s på test stadiet. Det ble satt main switch og Hovedsikring like etterpå.
  19. #19
    Hifi-interessert
    May 2007
    Tagget i
    0 Innlegg
    Mener jeg leste om denne for noen måneder siden på diyaudio.com eller hvor det nå var. Etter hva jeg forsto var det en salgsavdeling som ikke hadde helt peiling som hadde kommet med noen av disse utsagnene. Hvorvidt dette stemmer eller ei kan jeg ikke gå god for.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
