Side 1 av 2 12 SisteSiste
Resultater 1 til 20 av 31
Abonnér på denne tråden
  1. #1
    ØivindJ
    Guest
    Troels sine "beist"
    Beste han har lagd noen gang sier han:
    http://www.troelsgravesen.dk/JA8008_DTQWT.htm
    "150 liters" (Horn) beist
    Hvilke tanker har de klarsynte rundt disse?
    (Mye/lite Resonanser ?)
    Bilder:
    http://www.troelsgravesen.dk/download/DTQWT.zip
    Foran:
    ..og en trenger kanskje ikke sub:
  2. #2
    Æresmedlem Valentino's Avatar
    Apr 2008
    Tagget i
    1 Innlegg
    Troels sine "beist"
    Mmmmmm, Beymabasser!
    Men hva skal folk med disse pingleforsterkerne?
    Vik fra meg, O kjetterske Vranglærere! Jeg hører forskjell på alt! Halleluja!
    Anleggstråd: Bipolare Valentinos drodleDipol
    And you can't find your waitress with a Geiger counter and she hates you and your friends and you just can't get served without her
  3. #3
    ØivindJ
    Guest
    Troels sine "beist"
    Spare masse penger på å kjøpe færre te-lys.
  4. #4
    Hifi Freak Haavard's Avatar
    Nov 2002
    Lena
    Tagget i
    3 Innlegg
    Troels sine "beist"
    De er jo ikke veldig ulike H6 i måten de er oppbygd på.
    H6 er jo en ganske ok høyttaler spør du meg.
    Håvard
    Esoteric x03se Sacd & Veridian Utopia dac
    Thor Audio into First watt b4
    Heart DoubleBeat 300b monoblokker
    Lectron JH50
    Great Plains Audio 414a, 288a, 802a
    Lakrissnorer fra HGA & hjemmestrikket sølv
    Hornalliansen
  5. #5
    ØivindJ
    Guest
    Troels sine "beist"
    Høres jo veldig flott ut:
    The DTQWT construction has an 8" front driver and two 10" rear mounted drivers, all connected with positive polarity. They're placed opposite to one another and the rear drivers are fed through a huge coil, thus only adding weight to the lower octaves. All drivers load a center horn and you may ask whether the large bass drivers won't have an impact on the front driver from sharing the same open space and the answer is yes - and this is intentional. Air goes where pressure is low, thus when the rear bass drivers move inwards, they will push air into the large center horn and by doing so they will suck air from the front horn and pull the membrane of the front driver. Obviously the front driver will do the same thing for the bass drivers. We have a situation similar to a push-push configuration of two opposite placed bass drivers in a vented cabinet.
    The subjective experience from this is a cleaner midrange, distortion has been lowered at high SPLs and yes - we have more bass. In fact a lot more bass. The typical quality of the bass from a horn is quite different from conventional high mass/low efficiency bass drivers in small vented enclosures. The DTQWT delivers deep, dynamic and dry bass - anything but boomy.
  6. #6
    Apr 2008
    Tagget i
    1 Innlegg
    Troels sine "beist"
    Nesten like bra som bass fra bittesmå trykkamre da?
  7. #7
    Hifi Freak el_mariachi's Avatar
    Nov 2002
    Tagget i
    0 Innlegg
    Troels sine "beist"
    Sitat Sitat fra Valentino
    Ser man det, han har tatt til fornuften.
    Former hellraiser & messageboard pyromaniac.............................
  8. #8
    Hifi Freak sclalars's Avatar
    May 2006
    Skedsmokorset
    Tagget i
    0 Innlegg
    Troels sine "beist"
    Sitat Sitat fra el_mariachi
    Tydeligvis fornøyd med dine du òg
    Lars
    Hovedanlegg: Brukbart
  9. #9
    Nov 2002
    Tagget i
    0 Innlegg
    Troels sine "beist"
    Sitat Sitat fra sclalars
    Lars
    Jepp, bruker ikke du en slik også?
  10. #10
    Hifi Freak Rune S's Avatar
    Apr 2002
    Tagget i
    0 Innlegg
    Troels sine "beist"
    Hørning er bygget på samme prisnipp :
  11. #11
    Hifi Freak norcad's Avatar
    Feb 2006
    Tagget i
    0 Innlegg
    Troels sine "beist"
    Sitat Sitat fra Haavard
    Håvard
    Sorry Haavard, mener ikke å si noe galt om H6, men her finnes da nær sagt ingen sammeligning?
    Troels sin konstruksjon er/har: Quarterwave, 3-veis, doble basser, 2. og 3. ordens delefilter, waveguide på diskanten, evnen til å flytte mye luft pga 8" + 2 x 10", jevn frekvensrespons osv osv
    Absolutt en høyttaler det ville være morsomt å låne øret til. Ikke minst hans egenkonstruerte mellomtone er spennende.
    Ingen tvil om at Troels vet hva han driver med. Imponerende at noen kommer frem med så mange og omfattende konstruksjoner på DIY nivå.
  12. #12
    ØivindJ
    Guest
    Troels sine "beist"
    Hvor mye tror dere egentlig denne friksjonen i mellom lufta fra bassen og mellomtonen har å si?
    I tillegg til at to-veis`n har en litt mere normal størrelse, så blir det jo også billigere å bygge den først, og evetuelt noe bass greier etterpå. Det muliggjør jo hundrevis av watt til bassen også, men da blir det kanskje ikke hornbass da, hmm..
    Spennende dette med lufttrykket fra åtte-tommeren, når Troels sier at dette er det mest "transient villige" han noensinne har bygd.
    Den fine matchen imellom diskant og mellomtone er selvsagt også et kjempepluss.
  13. #13
    Nov 2002
    Lena
    Tagget i
    3 Innlegg
    Troels sine "beist"
    Sitat Sitat fra norcad
    Håvard
    Tenkte mest på likheter i kassen jeg da.
    Håvard
    Lectron JH50
    Hornalliansen
  14. #14
    ØivindJ
    Guest
    Troels sine "beist"
    Mye resonanser i dine eller, Håvard ?
    Kan det være endel å hente på å forsterke kabinettet på begge konstruksjonene?
  15. #15
    Nov 2002
    Lena
    Tagget i
    3 Innlegg
    Troels sine "beist"
    Sitat Sitat fra ØivindJ
    Resonanser?
    Vet ikke helt jeg, Norcad har målt dem en gang. Var vel ikke resonanser vi hang oss mest opp i.
    De originale H6 er konstruert med 25 mm mdf i front og 15 mm i sidenene. De jeg har laget har 22mm rund baut. Lufta kommer iallefall ut i disse Hullet under er stort nok til at en del luft kan komme ut.
    Uavhengig av Troels sin konstruksjon, så har jeg samen med min kompis i Ungarn tenkte tanken om en H6 med en 8", H8 . Ønsket er utfra å få mer bass. Større elementer har ikke alltid samme "speed", og en forutsetning for å gjøre det blir nok at de kan låte like uanstrengt og transparente som H6 med 6,5". I tillegg må bassen være like definert og stram. Orker ikke udefinert boomy bass bare for åt de skal gå lenger ned i frekvens. Må ikke glemme mellomtonen, den må være like god tilstedeværende som i de originale H6/Clone H6.
    Håvard
    Lectron JH50
    Hornalliansen
  16. #16
    ØivindJ
    Guest
    Troels sine "beist"
    Resonanser?
    Sånn "boomy". Sikkert neppe så ille med 22mm og det hornet diagonalt inne i kassa (som forsterkning).
    Fillern, du vet hva jeg liker å høre du og..
    Målte dere kurven på dine eller?
  17. #17
    Nov 2002
    Lena
    Tagget i
    3 Innlegg
    Troels sine "beist"
    Resonanser?
    Som den Audio Note mannen jeg tror du er, så er vel H6 noe du kan like.
    Håvard
    Lectron JH50
    Hornalliansen
  18. #18
    ØivindJ
    Guest
    Troels sine "beist"
    Hmm, det er en hel rekke argumenter for Troels sine også. Bl.a:
    - Den fine matchen diskant- og mellomtone element.
    - Vi vet at han har fått opp følsomheten på diskanten nok med det lille hornet.
    - Frekvens kurven
    - Muligheten for å velge modellen med hornbass.
    (- og han sier selv at disse 8" også er lynraske.)
    Mener ikke å kverulere, bare klør meg selv i hue litt..
  19. #19
    ØivindJ
    Guest
    Troels sine "beist"
    Forundrer meg noe helt fantastisk lite om H6 med en sånn elf-sub, låter svært bra også.
  20. #20
    May 2006
    Skedsmokorset
    Tagget i
    0 Innlegg
    Troels sine "beist"
    Jo, det har du helt rett i
    Og , det skal være sagt, jeg er mega fornøyd med det elementet.
    Lars
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
