Troels sine "beist"
JB rünnhilde
Mmmmmm, Beymabasser! 8)
Men hva skal folk med disse pingleforsterkerne? ;D
Haavard
Lena
De er jo ikke veldig ulike H6 i måten de er oppbygd på.
H6 er jo en ganske ok høyttaler spør du meg.
Håvard
Ø
ØivindJ
Høres jo veldig flott ut:
The DTQWT construction has an 8" front driver and two 10" rear mounted drivers, all connected with positive polarity. They're placed opposite to one another and the rear drivers are fed through a huge coil, thus only adding weight to the lower octaves. All drivers load a center horn and you may ask whether the large bass drivers won't have an impact on the front driver from sharing the same open space and the answer is yes - and this is intentional. Air goes where pressure is low, thus when the rear bass drivers move inwards, they will push air into the large center horn and by doing so they will suck air from the front horn and pull the membrane of the front driver. Obviously the front driver will do the same thing for the bass drivers. We have a situation similar to a push-push configuration of two opposite placed bass drivers in a vented cabinet.
The subjective experience from this is a cleaner midrange, distortion has been lowered at high SPLs and yes - we have more bass. In fact a lot more bass. The typical quality of the bass from a horn is quite different from conventional high mass/low efficiency bass drivers in small vented enclosures. The DTQWT delivers deep, dynamic and dry bass - anything but boomy.
JB rünnhilde
Nesten like bra som bass fra bittesmå trykkamre da? ;D
norcad
Håvard
Sorry Haavard, mener ikke å si noe galt om H6, men her finnes da nær sagt ingen sammeligning?
Troels sin konstruksjon er/har: Quarterwave, 3-veis, doble basser, 2. og 3. ordens delefilter, waveguide på diskanten, evnen til å flytte mye luft pga 8" + 2 x 10", jevn frekvensrespons osv osv
Absolutt en høyttaler det ville være morsomt å låne øret til. Ikke minst hans egenkonstruerte mellomtone er spennende.
Ingen tvil om at Troels vet hva han driver med. Imponerende at noen kommer frem med så mange og omfattende konstruksjoner på DIY nivå.
Ø
ØivindJ
Hvor mye tror dere egentlig denne friksjonen i mellom lufta fra bassen og mellomtonen har å si?
I tillegg til at to-veis`n har en litt mere normal størrelse, så blir det jo også billigere å bygge den først, og evetuelt noe bass greier etterpå. Det muliggjør jo hundrevis av watt til bassen også, men da blir det kanskje ikke hornbass da, hmm..
Spennende dette med lufttrykket fra åtte-tommeren, når Troels sier at dette er det mest "transient villige" han noensinne har bygd.
Den fine matchen imellom diskant og mellomtone er selvsagt også et kjempepluss.
Haavard
Lena
Håvard
Tenkte mest på likheter i kassen jeg da.
Håvard
Ø
ØivindJ
Mye resonanser i dine eller, Håvard ?
Kan det være endel å hente på å forsterke kabinettet på begge konstruksjonene?
Haavard
Lena
Resonanser?
Vet ikke helt jeg, Norcad har målt dem en gang. Var vel ikke resonanser vi hang oss mest opp i.
De originale H6 er konstruert med 25 mm mdf i front og 15 mm i sidenene. De jeg har laget har 22mm rund baut. Lufta kommer iallefall ut i disse ;D Hullet under er stort nok til at en del luft kan komme ut.
Uavhengig av Troels sin konstruksjon, så har jeg samen med min kompis i Ungarn tenkte tanken om en H6 med en 8", H8 ;D. Ønsket er utfra å få mer bass. Større elementer har ikke alltid samme "speed", og en forutsetning for å gjøre det blir nok at de kan låte like uanstrengt og transparente som H6 med 6,5". I tillegg må bassen være like definert og stram. Orker ikke udefinert boomy bass bare for åt de skal gå lenger ned i frekvens. Må ikke glemme mellomtonen, den må være like god tilstedeværende som i de originale H6/Clone H6.
Håvard
Ø
ØivindJ
Haavard skrev:
Sånn "boomy". Sikkert neppe så ille med 22mm og det hornet diagonalt inne i kassa (som forsterkning).
Fillern, du vet hva jeg liker å høre du og.. ::) :)
Målte dere kurven på dine eller?
Haavard
Lena
Som den Audio Note mannen jeg tror du er, så er vel H6 noe du kan like.
Håvard
Ø
ØivindJ
Hmm, det er en hel rekke argumenter for Troels sine også. Bl.a:
- Den fine matchen diskant- og mellomtone element.
- Vi vet at han har fått opp følsomheten på diskanten nok med det lille hornet.
- Frekvens kurven
- Muligheten for å velge modellen med hornbass.
(- og han sier selv at disse 8" også er lynraske.)
Mener ikke å kverulere, bare klør meg selv i hue litt.. :)
Ø
ØivindJ
Forundrer meg noe helt fantastisk lite om H6 med en sånn elf-sub, låter svært bra også. :)
sclalars
Skedsmokorset
el_mariachi skrev:
Jepp, bruker ikke du en slik også?
Jo, det har du helt rett i :)
Og , det skal være sagt, jeg er mega fornøyd med det elementet.
Lars
Haavard
Lena
- Frekvens kurven
Men det er noen utrolige filter der da, dobblet så mange komponeneter som i H6 clonen. Som kanskje kveler alt av "speed".
Håvard
Ø
ØivindJ
Troels selv var helt overbevist om at de store låt langt bedre, enn de "små`e" pluss sub. (Hornbass fan..)
Bruke Behringer og egen bass amp på de store? :)
(Litt kontroll er jo kjekt å ha..)
De par hundredelenes forsinkelse bør vel ikke spille all verdens rolle?
(Får jo ev. de på en digital sub forsterker også?)
folkeb
Er det noen her til lands som har hørt enten TQWT eller DTQWT høyttalerne? Er fristet, men må nøye meg med TQWT varianten...lite lytterom. Vil ha en høyttaler med god dynamikk!
Haavard
Lena
H6 cloner. ;D
Håvard
folkeb
Ser at flere har bygget og er godt fornøyde med H6 clone, men er det noen på forumet som har bygget troels sin TQWT eller DTQWT?
folkeb
Da er TQWT bestilt og etter sigende i posten. Snart blir det lyd... ;D Har alltids muligheten til å oppgradere til DTQWT senere. Lager en egen byggetråd etterhvert.
Haavard
Lena
Har du fått begynt?
Håvard
folkeb
Kabinettene er halveis på vei, har limt sammen mye av "innmaten" og regner med å laget til frontplaten i løpet av uken. Venter fortsatt på elementer og delefilter, men de kommer nok frem i løpet av uken det også.
Har tatt noen bilder underveis. Legger ut bilder etterhvert i en egen tråd.
- F
Ø
ØivindJ
Hehe, ting tar tid. :)
Tipper nesten alle som har prøvd å bygge selv, har blitt overrasket over hvor lang tid det egentlig tar. Hundre små og store avgjørelser som må taes underveis.
From the onset of the project there was no doubt in my mind that it had to be paper, providing proper strength and internal damping at the same time.
Given the right fibre composition, we don't have to coat the membranes at all. Coating is usually modern chemical polymers like PVA glue, which will dampen cone break-up, ad mass and reduce sensitivity.
So, why an 8 inch driver? I'm sure the 8" driver in an arbitrarily derived ideal size for a dynamic driver. The best balance between bass extension, sensitivity (cone mass) and high-frequency extension.
I've often found drivers with foam surrounds superior in performance compared to drivers with rubber surround. I've changed quite a few drivers' surround from rubber to foam and always found an increase in transient attack and sensitivity, generally a more vivid sound without compromising the drivers' frequency response.
What I've tried here is to make an overall balanced sound from the JA8008/TW034. Compared to all other speakers I've made, the area where this speaker differs the most is in its ability to reveal musical transients. The speed and attack it can produce is something none of all the other speakers on this website can manage. It's fast, very fast. A drum solo will kick butt, even from a 10 wpc amplifier.
Vil tro at du ikke blir skuffet.
ØivindJ
Bigger, better, stronger, faster :eek: ...
A DTQWT-12 is on the drawing board and be prepared for 152 cm height, 33 cm width and 60 cm depth. 2 x 12" basss drivers will load the large horn and deliver effortless deep bass performance. A possible planar tweeter will be tried here as these are available in a number of varieties, but many with efficiency making them suitable for the 8008 midbass driver.
Audiodidakt
JA8008 har en (bl/mms)*1000 på 517
Seas sin 8" Nextel har tilsvarende faktor på 440 og magnesium på nedre 300-tallet.
Det finnes dog andre kjappe 8" elementer også:
Seas sin Exotic 8" (med treplugg): 662
Ciare 850Ndw: 703
Til sammnligning Seas sin 15 cm nextel med hex-magneter: 785
(Men den må jo slå lengre for å pushe like mye luft)
Mvh Gisle
