Side 1 av 4 123 ... SisteSiste
Resultater 1 til 20 av 67
Abonnér på denne tråden
  1. #1
    Moderator bambadoo's Avatar
    Oct 2002
    Tagget i
    2 Innlegg
    Ny volum kontroll-pot?
    Har forsket endel på forskjellige potmeter, attenuatorer, TVC etc.
    Grunnen er at jeg ikke er sikker på hva jeg skal gå for til preampen. Har tkd cp2511 idag som er glimrende, men vurderer en motorisert versjon av denne slik at remote kontroll på volum er en mulighet.
    Evt. tkd sin stepped attenuator (41 steps) - skal være kjempebra og koster 250usd fra www.percyaudio.com
    I min søken kom jeg over denne: (Ser snaisen ut)
    http://www.tribute-audio.nl/
    Gå inn på news.
    Inductive Volume Control
    The TRIBUTE volume control is an inductive control, which means that unlike "normal" volume controls (which use some sort of resistive element) an inductive element is used.
    The main advantage of using an inductive element is the low DC resistance of the windings.
    A standard resistive volume control is 10k, 50k or 100k. The Tribute inductive volume control has a DC resistance of only 33 ohms, which results in a more transparent and dynamic sound, especially at low volume sinductive volume controlettings.
    The AC resistance can be calculated and is frequency dependent. The Tribute volume control has an AC resistance of about 20k at 20Hz and 1Mohm at 1kHz.
    Most inductive volume controls are wound as transformers with primary and secondary windings.
    In contrast, to reach the ultimate in dynamics, bandwidth and transparency, the Tribute volume control is wound as an autotransformer, which means that a single, tapped coil is used.
    The pictures show that the volume control is a complete stereo control by mounting the coils on a 24 positions ELMA switch, also to keep connections as short as possible.
    Mono controls are also available.
    Further specifications:
    * inductance 150 Hy's;
    * DC resistance 33 ohms;
    * maximum input 6 VRMS at 20 Hz;
    * width / height 5cm (2 inches);
    * required mounting depth 10 cm (4 inches) for the stereo control;
    * required mounting depth 5,5 cm (2,2 inches) for the mono control.
    Kommentarer?
    I don't believe in system matching. If something is good, it's good. If it only sounds good under certain conditions, it is not good - it is incorrect. - Charles Hansen
  2. #2
    Overivrig entusiast Frode's Avatar
    Dec 2002
    Tagget i
    0 Innlegg
    Toonz her på forumet bruker vel tribute: http://www.hifisentralen.no/forum/in...html#msg318990.
    Frode
  3. #3
    Hifi Freak Erland's Avatar
    Apr 2003
    Tagget i
    0 Innlegg
    Denne tribute-saken ser da teknisk sett ut som en "mini-TVC".
    Siden denne kommer som en "ferdig pakke" som du slipper å lodde, er det helt genialt.
    Vær så snill og kjøp den og fortell oss hvordan den funker.
    Personlig har jeg ikke brukt for flere, men dette er jo et høyaktuelt tema for tiden.
    Member of NBPM
  4. #4
    Hifi Freak VegardW's Avatar
    Feb 2007
    Kolsås
    Tagget i
    0 Innlegg
    Enig med Erland.Noen som ser ulemper/svakheter ut ifra specs?
    Vegard
    Exadevice/Buffalo dac3m eksternt lc psu/1794nosdac /Tribute autoformer/10 linjetrinn Tribute/801a se/ 13e1se/el 34pp/
    841/ux250 se/ eml30a/eml 50 se/ eml30a/gm70 se
    Studer a-810, Supravox 400 fieldcoil/Tad 4001/ 1505 klughorn
  5. #5
    Overivrig entusiast slarssen's Avatar
    Mar 2003
    Tagget i
    0 Innlegg
    Den TVCn så jo svært intressan ut! Løp å kjøp! Tribute er kjent for å ha svært høy kvalitet! Det ligger et lite shoot-out av det som kanskje var en tidlig utgave av denne på www.vt52.com under "DIY corner" og "Projects" og "TVC shoot-out"
    Den eneste bakdelen er vel muligens at Tribute er ganske kjent for svært lange leveringstider (før i allefall, det kan h forbedret seg de siste årene).
    - Stig
    HTPC - WaveIO USB - RAKK-DAC MKIV m/passive LL1674 - Nottingham Horizon m/RB250 - Dynavector DV10X5 - DIY JFET SE RIAA - DIY Effekt med KT66/6550 PP-CFB - Coincident Triumph Signature Extreme
  6. #6
    Dec 2002
    Tagget i
    0 Innlegg
    Sakset fra en post på diyaudio.com:
    I tried S&B TX102s, Slagle autoformers (intact audio) and currently Tribute autoformers. All of them really good but the Tribute got the edge and that's what I'm using right now.
    Her er posten: http://www.diyaudio.com/forums/showt...719#post857719
    Frode
  7. #7
    Hifi-entusiast jbc's Avatar
    Jun 2003
    Tagget i
    0 Innlegg
    Odd
    Jeg nevnte på mail at jeg hadde en TVC liggende ubrukt. Om du skulle finne ut at du vil oppgradere utgangstrafoene i AN preen kan jeg være åpen for et bytte av de gamle mot min TVC. :-)
    Jørgen
  8. #8
    Feb 2007
    Kolsås
    Tagget i
    0 Innlegg
    Sendte en mail til tribute.Ikke den kjappeste til å svare, men hyggelig.Leveringstiden er ca 3 uker.prisen er 365 euro.transport i tillegga får man komplette kontroller:Integerert med 24 pos elma swithces.Prisen er den samme for 2x mono og 1x stereo.
    Vegard
  9. #9
    Oct 2002
    Tagget i
    2 Innlegg
    Kom over en ny attenuator for de som er interessert i slik.
    48 steps - ladder type
    http://www.khozmo.com/index.html
    Prisen skal ligge på 99$ for stereoversjonen.
    Fint bygget opp er de ihvertfall.
  10. #10
    Nov 2004
    Tagget i
    0 Innlegg
    Torget
    Sitat Sitat fra bambadoo
    Den var veeeldig sexy!
    Jeg har også en slik ALPS RK-50 liggende som skal inn i en preamp... én eller annen gang.
    Produsent av Whistler Audio kabler!
  11. #11
    Hifi Freak Diy Duke's Avatar
    Feb 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra whistler
    Shit det ser godt ud. Er det en attentuator ? Er det rigtigt det har 4 dæk ? Hvor kan det købes ?
    Hands of the compression Button music industri.
  12. #12
    Hifi Freak Haavard's Avatar
    Nov 2002
    Lena
    Tagget i
    4 Innlegg
    Den Alps saken er iallefall dyr nok
    Finner den her
    http://www.loudspeakershop.eu/alps-rk50-c-217_235.html
    Omregnet i norske priser 5890 kroner
    Håvard
    Esoteric x03se Sacd & Veridian Utopia dac
    Thor Audio into First watt b4
    Heart DoubleBeat 300b monoblokker
    Lectron JH50
    Great Plains Audio 414a, 288a, 802a
    Lakrissnorer fra HGA & hjemmestrikket sølv
    Hornalliansen
  13. #13
    Feb 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra Haavard
    Finner den her
    Håvard
    Shit igen. Og sådan noget shit at den er med Carbon. Ikke noget Carbon i mit anlæg bortset fra i Højttalerne. Jeg vil have præcision i bassen ikke bulder.
  14. #14
    Hifi Freak Cobra2's Avatar
    Feb 2003
    Tagget i
    0 Innlegg
    Album
    Of all the things I've lost, I miss my mind the most.
    For sale:
    http://www.hifisentralen.no/forumet/...ser&userid=701
  15. #15
    Nov 2004
    Tagget i
    0 Innlegg
    Torget
    Gjør et Google-søk på "Lightspeed attenuator".
    Spennende for å si det mildt! Hvis det virkelig funker så bra som mange hevder, er det jo en liten revolusjon.
  16. #16
    Jul 2006
    Tagget i
    0 Innlegg
    Sjekk: SKA-audio OptiVol
    Disse "frikobler" akkurat som en trafo, men uten hysteresetap.
    Med predefinert utgangsimpedans skulle disse være mer enn intr. for ICE-forsterkere.
    Radionette Kurer
  17. #17
    Nov 2004
    Tagget i
    0 Innlegg
    Torget
    Sitat Sitat fra wilbur-x
    Tror dette er en forenklet og dårligere variant enn Lightspeed-versjonen.
    OptiVol er diskutert på en av Lightspeed-trådene på diyaudio.com.
  18. #18
    Feb 2007
    Tagget i
    0 Innlegg
    Jeg syntes alt fra Gregg Ball er junk.
  19. #19
    Jul 2006
    Tagget i
    0 Innlegg
    Takker for info, skal sjekke tråden på diy.com.
    Lightspeed link:
    http://diyaudioprojects.com/Solid/DI...ve-Attenuator/
    Radionette Kurer
  20. #20
    Hifi Freak mteinum's Avatar
    May 2007
    Øya
    Tagget i
    0 Innlegg
    Album
    Goldpoint har en del varianter: http://www.goldpt.com/
    TIDAL|> Mac Mini / Roon |> SOtM sMS-200ultra |> Mytek Manhattan II |> FirstWatt B5 |> Trafomatic Audio |> Fostex T500mkII, FE203En-S / Acoustic Elegance OB.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
