Moet Audio
Butikk YBA Passion Pre550 MK2 - i demo
Forforsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 87.800
Annonse beskrivelse
Annonse nummer: 241802
Organisk, oppløst og vellydende preamp med en særdeles god dac. Står i demo sammen med tilhørende effekt-trinn.
https://www.moetaudio.com/produkt/forsterker-1/forforsterker/yba-2/yba-passion-pre550a-preamplifier
Several things distinguish the PRE550 MK2 from other digital/analog preamps. It is possible to turn off the digital section when playing an analogue source. The analog section has three inputs — one balanced (XLR), one unbalanced (RCA), and one video pass-through (RCA). There are two sets of RCA outputs and one set of XLRs.
There is a wide choice of digital inputs — I2 S (RJ45), AES/EBU (XLR), S/PDIF (TosLink, coaxial, BNC), and USB – plus there is a network input (RJ45) that accepts signals from a 10 or 100Mbps network. Built-in Apple AirPort Express support enables the PRE550A to work via a wireless AirPort Express network. It has a direct input for an Apple iPod or iPhone that bypasses the Apple’s internal DAC and uses only the PRE550A DAC. There’s also an S/PDIF output jack, should you want to send a digital signal to another component.
The asynchronous USB 2.0 connection for a computer requires a driver if you’re running Windows, but not with a Mac or Linux computer.
Product type
Preamplifier
Audio Outputs
2 RCA 1 Balanced 1 S/PDIF
Gain
+6dB
SNR
>105dB
Frequency Response
20Hz – 20kHz (-0.5dB)
THD+N (20Hz - 20kHz)
<0.003%
Inputs
7 Digital Signal Inputs
2 RCA Analog Signal Inputs
1 Balanced Analog Signal Input
1 Balanced Input (Mono)
Airplay
YES
DAC
Dual Cirrus Logic High Performance 24bit/192kHz
Display
OLED
Display Brightness
Adjustable from remote
Power Supply
2 Linear power supplies with high performance
transformer 190VA
Color / Finish
Natural aluminium
Dimensions (w x d x h)
430 x 412 x 118mm
Weight
12.5 kg
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
