Ta kontakt for demo og tilbud
YBA Passion IA350 MK2 Integrated Amplifier
A sound stage is meant to be panoramic and the IA350 fills the room. The separation of the channels gives us a wide sound scene yet does not go beyond the surroundings of the loudspeakers. The IA350 adapts superbly to the dimensions of the listening room, but also to the speakers. The dynamics allow us to listen serenely and absolutely to all styles of music under all conditions.
Staying with the uncluttered style synonymous with YBA, the front panel has simply an input and volume selector. The turn on switch is cleverly concealed beneath the front left hand side of the amplifier.
The source selector toggles between many different inputs – both analog and digital. The digital inputs include an S/PDIF (75 Ohm) Coaxial digital input, a USB (24/192KHz) plus AES/EBU, I2 S, and iPod, all of which receive digital signals from separate digital components. The analog inputs include 2 RCA and 1 Balanced. All digital inputs automatically adjust to any of the standard digital-audio data-rates from 16/44.1Khz to 24/192Khz. There is one pair of RCA speaker outputs.
It is possible to switch the power to the digital section off completely if your wish is to listen at times to purely analog. The Passion IA350A also has a pre-out bypass feature, if, for example, you wish to connect an active subwoofer or active loudspeakers.
Should you wish to use your PC as a source, a driver download is required. It can be found in Reviews and ocumentation. This is only necessary for Windows, MAC users do not require the download.
Product type | Integrated Amplifier |
Power output | 115W into 8Ω – per channel // 160W into 4Ω – per channel |
Audio Outputs | 1 Pair Speaker Outputs, 1 Pre-Out RCA & 1 Digital S/PDIF Coaxial |
Audio Inputs | 1 Balanced XLR & 2 RCA |
USB Input | XMOS XU208 – PCM 32bit / 768 kHz & DSD512 |
Bluetooth Input | Qualcomm CSR8675 BT5.0 – LDAC, aptX, aptX HD, AAC, SBC |
Other Digital Inputs | Coaxial, AES/EBU (XLR) & I2S (RJ45) |
SNR | >100dB |
THD+N | <0.03% (20 Hz – 20 khz) |
D/A Converter | Dual Analog Devices AD1955 – Native support up to 24/192 & DSD64 |
Frequency Response | 20 Hz – 20 kHz (-0.5 dB) |
Power Supply | Linear power supply with high performance Ul-core transformer 320VA |
Remote control | Full function – full metal chassis |
Color / Finish | Natural aluminium |
Dimensions (w x d x h) | 430 x 380 x 108 mm |
Weight | 15 Kg |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
