UPGRADED POWER SUPPLY
The X1 power supply is now available separately as an upgrade for S1 / A1 / T1 / U1 owners
NEW
SOLID BILLET
CNC CASING
SEPARATE DIGITAL
& ANALOGUE
CIRCUITRY
LOW-NOISE
LINEAR
REGULATOR
CUSTOM CABLE FOR
S1 / A1 / T1 / U1
COMPATIBILITY
WHY UPGRADE
Our flagship PSU is now available to a wider audience. Whether you partner it with S1, A1, T1 or U1, not only will you benefit from its sleeker finish and heavyweight solid-billet construction, owners are reporting improvements to every aspect of their favourite music.
The perfect upgrade for your LUMIN
Solid billet construction using all the same techniques as your main chassis
Thick aluminium walls provide even more shielding
Available in anodised black and raw silver
Supplied with a custom cable for S1 / A1 / T1 / U1 compatibility
Separate digital and analogue circuitry
Low-noise Linear Regulator
The highest quality components used throughout
SPECIFICATION
LUMIN X1 PSU UPGRADE SPECIFICATION
PHYSICAL:
FINISH:
Raw brushed aluminium or black anodised brushed aluminium
DIMENSIONS:
106mm (W), 334mm (D), 60mm (H), 4kg
CABLE LENGTH:
PSU to LUMIN DC Umbilical Cord: 1.5m
COMPATIBILITY:
LUMIN S1 / A1 / T1 / U1
POWER:
110V - 120V AC 50/60HZ 0.2A
or
220V - 240V AC 50/60HZ 0.2A
NEW
SOLID BILLET
CNC CASING
SEPARATE DIGITAL
& ANALOGUE
CIRCUITRY
LOW-NOISE
LINEAR
REGULATOR
CUSTOM CABLE FOR
S1 / A1 / T1 / U1
COMPATIBILITY
WHY UPGRADE
SPECIFICATION
PHYSICAL:
FINISH:
DIMENSIONS:
CABLE LENGTH:
COMPATIBILITY:
POWER:
or
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
