Butikk Unik mulighet - YBA Signature Pre MKII / Signature Power Amp
Effektforsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Buskerud
Pris
Kr 189.450
Annonse beskrivelse
Annonse nummer: 257441
Unik mulighet på YBA Signature Pre MKII + Signature Power Amp
Strøkent forsterkersett fra YBA sin Signature serie selges pga at nye demo
modeller skal på plass.
Settet selges med 50% rabatt.
SIGNATURE PRE MKII
Offers a XLR input, an array of 5 RCA inputs and also a dedicated MM Phono input. On the side of outputs, Mark II version implements a pair of XLR outputs and single RCA output. Making it a versatile choice for wide range of Hi-Fi setups, all easily controlled with our classic YBA remote controller.
In the centre of the embossed YBA logo on the front panel is a standby switch, which responds to the touch of a finger. The source selector rotates through 10 different inputs and phase and mute switches are on the right-hand side along with the rotary encoded volume control.
New Mark II version brings quite a few improvements in its digital section, mainly thanks to the Analog Devices AD1955 DAC, with a native support of PCM up to 24 bit / 192 kHz and DSD64. USB input was also significantly upgraded with the XMOS controller, offering the top-quality sound with a direct connection to your computer. Optical and coaxial inputs are still included for use with other digital sources.
SIGNATURE POWER AMP
The circuit used in this YBA amplifier is completely symmetrical; this cancels any defects introduced via the power source, minimizes parasitic ground currents and avoids any need for passive components in the signal path.
The number of components has been minimized; the signal traverses only transistors. No passive components alter the original purity of the musical signal. The input stage is of the complementary double differential type; it is followed by a pre-driver stage, which allows the adaptation of the impedance and initial amplification of voltage. The pre- driver stage is followed by a third stage, which completes the amplification of voltage; it distributes the current and voltage necessary to the output stage, which is directly coupled to the speakers.
The geometry of the circuit has been optimized to reduce the distances between components and the connecting wires to the absolute minimum: only a few centimetres at the input and output of the
amplifier. The transformers are suspended in order to reduce the transmission of their vibrations to the rest of the amplifier.
Leveres med garanti og settet fremstår som nytt.
Ny pris for settet 378.900.-
Nå 189.450.-
Sound of Heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
sound of heaven
Torget karakterer
Vurderinger (3)
Andre annonser av sound of heaven
