Et par meget velholdte og velspillende Gallo A'Diva TI høyttalere med gulvstativ i kremhvit finish. Høyttalere er kablet med kvalitetskabler. Nypris med kabler ca. 9.000 kroner
Til komplettering for å ta seg av område 42Hz til 200Hz følger med en Mirage MM-6 mini-subwoofer. Nypris var 3.990
Spesifikajson for Gallo A'Diva TI:
The new Anthony Gallo Acoustics A'Diva Ti loudspeaker is a 5-inch sphere slightly larger than the original and venerable Gallo Micro that was a 4-inch sphere.
Think grapefruit and naval orange respectively.
The A'Diva Ti sports a frequency response of 76Hz- 22kHz when mounted on-wall (90Hz – 22kHz on stands)
87dB sensitivity and a nominal impedance of 8 ohms
Gallo specifies a 50-watt power handling (120 watts when used as "small" speakers in a surround-sound system).
The driver is Gallo's proprietary 3-inch full range pure titanium cone, hence the Ti designation. The metal diaphragm is damped by a paper dust cap and optimized with S-2 technology (details to follow). Connectors are gold-plated binding posts with plastic nuts that accept bare wire, spades, bananas and pins. The A'Diva Ti weighs in at 1.8 pounds each and is available in matte black, matte white and silver/gray.
Spesifikasjon for MM-6:
Amplifier Power Output - 800 Watts
Variable Low Pass Filter - 50Hz-200Hz
Bypass Variable Phase Control 0 degrees - 360 degrees
Power Mode Switch Off/auto/on
System Type - Single active, dual passive Frequency Response 42Hz-200Hz
Overall Dimensions - (HxWxD) 20 x 20 x 20 cm woofer Active: 6.5-inch (16.5 cm)
Black anodized aluminum cone with inverted Ribbed Elliptical Surround,
Passive: 2 x 6.5-inch (16.5 cm) Black anodized aluminum cones with inverted Ribbed Elliptical Surround
Product Finish High gloss black Settet spiller meget bra sammen.
Jeg spiller Galloene full-range og deler MM16 ved ca. 65 Hz. Dette med delefrekvensen, fase, etc. må du nok prøve deg frem til i ditt eget rom. For å få mest sømløs overgang mellom Galloene og MM-6 mater jeg signalet til MM-6 fra høyttalerutgangene på forsterkeren som driver Galloene full-range. Da får subwooferen samme klangfargen i bassområdet som hovedhøyttalere. Dette som et godt tips. Med sitt elegante utseende er høyttalere lett å plassere i alle interiører uten å være dominante. Kan plasseres helt mot bakveggen slik at de ikke tar plass ut i rommet. Subwooferen kan plasseres på dertil passende sted uten å måtte være synlig.
Prisen nytt var til sammen ca. 13.000 kroner. Brukte disse som musikkanlegg og til TV lyd på hytta, men må selge kun fordi våre nye små, søte barnebarn er meget interesserte i å leke med disse. Dette velspillende anlegg ble erstattet av en kjedelig lydplanke som ikke tiltrekker seg samme oppmerksomhet fra barnebarna...
Salgspris for høyttalere og subwooferen: kr. 5.200.
Jeg har ikke original emballasje så settet må hentes i Sandefjord, alternativt avtale en levering på strekningen Sandefjord - Oslo. Det tar liten plass selv i en liten bil.
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
