Pent brukte Synergistic Research Element Copper høyttalerkabler, 2 x 7ft (2,13m), internal biwiring, spader/spader (gullbelagt kobber).
Kablene er kjøpt nye i USA i 2013 (pris 1807 USD) og leveres med sølv og grå UEF Tuning Bullets samt 240V strømforsyning.
Prisen inkluderer frakt (helthjem).
Informasjon fra Synergistic Research;
Element Copper Speaker Cable with UEF Tuning Circuits
Element Copper speaker cables were voiced to compliment the inherent strength of copper with thunderous low frequency delivery and control in a flexible easy to manage profile.
With an overall diameter less than two No.2 pencils, Element Copper speaker cables deliver performance that surpasses even large unwieldy cables in a svelte and stealthy package.
- Exceptionally powerful in a small flexible package
- More holographic then our prior top of the line models
- Delivers performance well beyond its price point
- UEF Tuning Circuits632UEF Tuning Circuits
Specifications:
Copper Air Strings:
99.9999% pure mono crystal copper conductor with a separate ground conductor from shield
4 separate conductors: 2 signal, 2 DC Shield
Dielectric: Air (sealed)
Shielding: 30-volt, 250 milliamp Active Shielding
Geometry: Four channel
Hand Made in our California factory
Tricon 3rd Gen High Current:
Silver Copper Matrix: Mono crystal conductors with a separate ground conductor from shield
Dielectric: Teflon
Geometry: 3 channel with separate conductors for signal and DC ground
H.C.S.P Active:
Dielectric: Modified Polyethylene
Geometry: 2 conductor twisted pair + foil shield w DC drain wire
Spade or Banana Terminations:
Gold plated copper
Geometry Count:
Each Pair of Element Copper Speaker Cables are actually 3 separate pair of cables- 1 pair Copper Airstring with separate signal and ground conductors from shield / DC, 1 pair 3rd Generation Tricon High Current with separate signal, ground and DC shield conductors and 1 pair H.C.S.P. with separate signal and ground conductors from shield / DC
Power Supply:
1 Standard 30 volt MPC
Build Notes:
68 point-to-point hand soldered connections
Hand build time: 8 hours
Quantum Tunneling: 2 step process, one for signal / ground, one for Active Shielding conductors and shields
Specifications:
Copper Air Strings:
Dielectric: Teflon
H.C.S.P Active:
Gold plated copper
Geometry Count:
Power Supply:
Build Notes:
- Originalemballasje
- Nei
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
