Mye spilleglede i en kompakt høyttaler fra Swissonor, Sveits.
Les test her:
http://www.audiophile.no/nb-no/omtaler/hoytalere/item/1592-swissonor-b-a-c-h-8e
http://www.swissonor.ch/pdf/B.A.C.H.8e_e.pdf
Strøkent demosett i lys ask.
Drives lett av 11 w rørforsterker, eksempelvis Mastersound Dueundici eller SPEC RSA-777EX
Swissonor 8d, normal pris kr 29500.
Technical specification
Continuous noise AES standard…………………….………………………….50 W
Program power (6dB crest factor)…..…......……………………….…….…100 W
Peak power <1oms….……………………………………………......................150 W
Rated impedance…………………………………………………………………….....8 Ohm
Sensitivity (Thiele half space reference efficiency)…………………..…..94 dB(1W/1m)
Maximum acoustic output (1 loudspeaker)………………................….106 dB
Maximum acoustic output (pair of loudspeakers)……………….....….112 dB
Frequency range in-axis ……….…………………………………....52 – 15'000 Hz(+/- 3dB)
Recommended amplifier rating (tube amps)…………….........…….6 - 30 Watt at 8 Ohm
Recommended amplifier rating (solid state amps)................. 20 – 80 Watt at 8 Ohm
Maximum reasonable amplifier power……………….........................100 Watt at 8 Ohm
Low frequency adjustment range.................………………………..….+/-2 dB continued
Polarity : Positive voltage on red terminal gives forward cone motion
Housing : Handmade from plywood, at choice white lacquer or natural maple or wild cherry veneer
External dimensions (without feet)………………………... 440 x 570 x 226 mm
External dimensions (including feet)……………………… 440 x 790 x 226 mm
Les test her:
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
