Steinar.Sv
Sony TA-FB940R QS
Denne annonsen er utgått.
Integrert forsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Akershus
Pris
Kr 1.500
Annonse beskrivelse
Annonse nummer: 245790
Ganske så strøken forsterker, virker 100%
Mangler fjernkontroll
Rated output power
8 ohms at 1 kHz: 80/60 watts per channel according to DIN/IHF
4 ohms at 1 kHz: 120/95 watts per channel according to DIN/IHF
Total harmonic distortion: >0.008% at 10 W / 1 kHz
Frequency Response:
Phono MM: RIAA 20-20,000Hz ±0.5dB
High level: 7-300,000 Hz +0/−3 dB
Signal to noise ratio:
Phono: 94dB (IHF)
High level: 105 dB (IHF)
Output voltage/impedance:
Tape Rec 1, 2: 150 mV / 1 kOhm
Headphones: 10mW / 8 ohms
Allowable speaker impedance: >3.2 ohms for a pair
Damping factor: 500 at 8 ohms / 1 kHz
Loudness
Subsonic Filter
Originalemballasje
Nei
Orig. kvittering
Nei
Forsendelse
Avtales nærmere
Steinar.Sv
Torget karakterer
Vurderinger (1)
Andre annonser av Steinar.Sv
