Flott og solid rack med 5 hyller i valnøttlaminat fra italienske Solidsteel.
Listepris: NOK 11 954,-
Tilbudspris: NOK 9 000,-
Produktside
Tubes: painted aluminum (anodized) filled with damping material;
Hardware: Stainless steel;
Terminals: Iron AVP treated with zinc to eliminate the risk of rust;
Shelves: MDF wood, polymer laminate.
Sustainability for each shelf: 60 kg tested.
Weight: 35 Kg | 77.16 lbs
Outer Dimensions (mm):
W 584 D 430 H 1060
Inner Shelves Dimensions (mm):
W 500 D 430 H 205/205/205/205 mm
Produktside
W 584 D 430 H 1060
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
