Moiz Audio
Butikk Sbooster BOTW 15V - 16V Linear PSU Solgt
Denne annonsen er utgått.
Løse komponenter
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Pris
Kr 2.995
Kjøpt av
budda
Annonse beskrivelse
Annonse nummer: 174878
15V versjonen av Sbooster BOTW psu, fungerer med populære Auralic streamere og Martin logan høyttalere
https://positive-feedback.com/audio-discourse/audio-ramblings-the-auralic-aries-and-sbooster-linear-power-supply/
The Best of Two World Power & Precision ECO is the successor of our Best of Two Worlds Solution upgrade. For the BOTW P&P ECO we have applied a large number of innovative techniques in order to improve the sound quality of your Electrostatic Loudspeakers to a much higher level compared to a conventional linear audio power supply.
Versatile
Like the BOTWS we have equipped the BOTW P&P ECO 15V - 16V with an interchangeable DC-tip system. In addition, the BOTW P&P ECO power supply has a selectable output voltage of 15V, 15.5V and 16V. This last setting can be used with Sbooster Ultra upgrade or other quirky applications of Sbooster.
The BOTW P&P ECO 15V - 16V is available in a 100/110/115/120/220/230/240V AC 50/60Hz version. With your order, please select the version that meets your local mains voltage. Additionally, you can select one of the four mains cable variants. If you prefer to use a special audio grade power cord with the BOTW P&P ECO please note that the mains cable has to be equipped with an IEC 13 connector.
The packaging of the BOTW P & P ECO 15V - 16V includes:
1x BOTW P&P ECO
1x DC tip 0.7x2.5x9.5mm
1x DC tip 1.3x3.5x9.5mm
1x DC tip 1.7x4.0x9.5mm
1x DC tip 1.7x4.8x9.5mm
1x DC tip 2.1x5.5x9.5mm
1x DC tip 2.5x5.5x9.5mm
1x Manual
1x Mains cable of your choice
Check for downloads and specifications the "Additional Information"
Moiz Audio
Torget karakterer
Vurderinger (119)
Andre annonser av Moiz Audio
