Vi har i butikken vår fabelaktige Rotel Michi X3 og X5 i demo. De er ikke bare en nytelse for øynene, men også ørene! Kraftverk som samtidig spiller elegant og detaljert!
Michi-serien fra Rotel er utrolig godt priset, og gir vanvittig mye for pengene.
Kom innom og lytt til de. Er tilgjengelig for hjemlån.
https://www.moetaudio.com/butikk/forsterker-1/integrert-forsterker-1/rotel-michi
X3
The Michi X3 Integrated Amplifier delivers uncompromised audio performance conveniently packaged in an elegant industrial design. The X3 delivers 350 Watts of Class AB output power into 4 ohm loads maintaining musical accuracy with exceptional acoustic detail from the Analog, Digital, PC-USB, apt-X Bluetooth and Moving Magnet Phono Stage source inputs.
2 x 350 Watts of robust power
Class AB amplifier design
AKM premium 32-bit/768kHz Digital to Analog Converter
Bluetooth with aptX™ and AAC
Certified Roon Tested
Engineered with care.
DIMENSIONS (W × H × D)
485 x 150 x 452mm
19" × 6" × 17 3/4"
FRONT PANEL HEIGHT
132 mm (5.25")
POWER REQUIREMENTS
230V, 50Hz
POWER CONSUMPTION
500W
STANDBY POWER CONSUMPTION
Normal: <0.5W
Network Wakeup: <2W
NET WEIGHT
28.9kg (63.7 lbs.)
BTU RATING
1303 BTU/h
MAXIMUM POWER OUTPUT
350W/Ch (4Ω)
CONTINUOUS POWER OUTPUT
200W/Ch (8Ω)
TOTAL HARMONIC DISTORTION (THD)
<0.008%
FREQUENCY RESPONSE
Line Level Inputs: 10Hz - 100kHz (+0dB, -0.4dB)
Digital Inputs: 20Hz - 20kHz (0 ± 0.4dB)
Phono Input: 20Hz - 20kHz (+0dB, +0.4dB)
S/N RATIO (IHF "A" Weighted)
Line Level Inputs: 102dB
Digital Inputs: 102dB
Phono Input: 80dB
X3
485 x 150 x 452mm
19" × 6" × 17 3/4"
FRONT PANEL HEIGHT
132 mm (5.25")
POWER REQUIREMENTS
230V, 50Hz
POWER CONSUMPTION
500W
Normal: <0.5W
Network Wakeup: <2W
NET WEIGHT
28.9kg (63.7 lbs.)
BTU RATING
1303 BTU/h
350W/Ch (4Ω)
200W/Ch (8Ω)
<0.008%
FREQUENCY RESPONSE
Phono Input: 80dB
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
