Vi har Ett par fantastisk vakre og vellydende gulvstående i demo som spiller åpent, lett og dynamisk tross størrelsen. Et syn er de også!
Ordinærpris: 66.000,-
The engineering challenge behind the new Elba was to put in our entry level model the same enthusiasm, design expertise and innovation that we put in our higher-end speakers so as to give the listener the pleasure of a real high-end acoustic experience.
Made in Italy with superior materials and craftsmanship, Elba series 2 sports a twin 6.5” woofer each one featuring coated fibreglass cones for optimal stiffness and damping properties over membrane resonances and a re-designed motor system which minimizes power compression.
These two mid-woofers work in a vented loading volume where the ports are directly placed behind both the upper and the lower woofer units drastically reducing their time delay. Each aluminium damped port has been retuned optimizing turbulence and in accordance with the new motor parameters of the drive units. The result is a system with an increased bass frequency extension and control compared to its predecessor.
On top of the front baffle sits a 26 mm wide surround silk dome tweeter powered by a double magnet that offers an extended high frequency response to about 40kHz together with a great off-axis dispersion.
However, the high quality of the Elba is not limited to its drivers.
Hidden but critically important is the newly designed crossover, which carefully links the drivers together for a coherent emission on both vertical and horizontal axis and gives the Elba a drastically limited impedance variation, making it extremely compatible with a wide range of amplifiers. The use of audio grade capacitors exclusively customized for Rosso by ClarityCap, together with our new proprietary made in Italy inductors and precision thick film resistors, put the high-end quality of this circuitry beyond doubt.
The beautifully finished enclosure, made in Italy by skilled craftsmen, makes use of the multi-layer construction which, in a more sophisticated way, is to be found in all our models.
The use of multi-layered panels made of mechanically different materials, guarantees the right balance of sturdiness and damping properties thus forming the basis for a clean and powerful sound.
This is a simple, clean, elegant design which encompasses all the technology, expertise and performance, typical of a Rosso Fiorentino loudspeaker. A floorstander built to blend with style into your home capable of creating a dynamic and captivating high-end sound.
TECHNICAL SPECIFICATIONS
Type
2.5 -way rear-ported floorstander
Sensitivity
88 dBspl (2.83V, 1m)
Nominal impedance
6Ω (minimum 4Ω)
Drive units
40 Hz – 30 kHz (typical in-room bass resp. -6dB @35Hz)
Crossover frequencies
60 Hz – 2.2 kHz
Recommended amplifier power
30W – 150W into 8Ω with unclipped sound signal
Cabinet
solid HDF fiberboard, internal damping elements, 3 different absorbent materials
Dimensions
27 Kg (59.5 lb) each
Cabinet finish
Type
Sensitivity
Nominal impedance
6Ω (minimum 4Ω)
Drive units
- 1 x ø 26mm (1 in) hand treated textile diaphragm with wide surround
- 2 x ø 165mm (6.5 in) coated fiber glass cone woofer
60 Hz – 2.2 kHz
Cabinet
Dimensions
- Height: 1086mm (42.8 in) incl. plinth and spikes
- Width: 236mm (9.3 in) | 270mm (10.6in) including plinth
- Depth: 290mm (11.4in) | 320mm (12.6in) including plinth
Cabinet finish
- exclusive RF silky matt black coating
- black carbon fibre pattern leather (front panel)
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
