Ta kontakt for tilbud
Strong points
The Real Cable Cheverny-II XLR is a high-end modulation cable with a very strong section designed to connect an analog source to a hi-fi or home cinema amplifier.
The Real Cable Cheverny-II XLR cable is made of two separate conductors made of highly oxygen-free copper OCC (Ohno Continuous Casting) and ensures optimal signal transfer thanks to the use of twisted conductors, monoblock metal plugs with ClickLock technology and contacts Golden. Benefiting from an anti-vibration nylon braid, high-density braiding of the asymmetrical shielding and proprietary TDC (Time Difference Control) technology, the very strong section Real Cable Cheverny-II XLR cable has all the qualities necessary to deliver a message . balanced and natural sound. The sound stage is open, the bass deep, the mids rich and the treble very well detailed.
Strong points
- OCC Copper Linear Conductors
- Monoblock metal plugs
- gold contacts
- Anti-vibration nylon braid
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
