99.5% strøken.
Meget dynamisk og fantastisk mellomtone.
Real dual mono integrated amplifier NAD S300. It comes from the NAD?s high-end series, the Silver Line. Introduced for the first time around the year 1999, just after the legendary Gryphon Tabu Centuryhad stopped being sold. Why do I mention the Danish Gryphon? Well, because these are basically the same amps?
By the S300 you don?t need to ask yourself the question: Does it supply my speakers sufficiently? It definitely does! Extremely powerful gear putting out 2 x 100/200/300 @ 8/4/2 ? . Built like an armoured valuables truck, it weights 25,5kg.
The heart of the amp is a pair of huge, high-efficiency toroidal power transformers brought by Toroid. Each channel is
additionally equipped with 4 Nichicon power caps. Total capacity of accumulated power equals 40000uF per
channel. Power transistors Sanken 2 x 2SC2922 and 2 x 2SA1216, Alps potentiometer (fully motorized, very
precise), Meisei M4-24H relays, top quality speaker and input terminals, balanced XLR input, separate power transformer for non-audio circuits.
