Klassisk NAD reciever selges - NAD 7140 - perfekt til anlegg nr. 2, hytta, garasjen etc..
- God radio
- MM og MC Platespillerinngang
- Kan brokobles
- Kan brukes som ren forforsterker eller effektforsterker
Kosmetisk pen, fungerer som den skal & spiller flott
Selges for 500,-
Ta kontakt på pm, sms eller tlf 90986128
http://nadelectronics.com/download.php?100526163848-NAD_7140.pdf|Data Sheet - 7140 Stereo Receiver
http://nadelectronics.com/download....140.pdf|7140 Stereo Receiver - English Manual
Continuous output power into 8 ohm - 40W (16dBW)
Rated distortion (THD 20Hz - 20kHz) 0.03%
Clipping power (maximum continuous power per channel) 50W
IHF Dynamic headroom at 8 ohm +6dB
IHF dynamic power (maximum short term power per channel)
8 ohm 160W (22dBW)
4 ohm 200W (23dBW)
2 ohm 250W (24dBW)
Damping factor (ref. 8W, 50Hz) >50
Input impedance 22kW / 880pF
Input sensitivity (for rated power into 8W) 1V
Frequency response 6Hz - 50kHz +0, -3dB
Signal/noise ratio ref. 1W 100dB
ref. rated power 116dB
THD (20Hz - 20kHz) <0.03%
Dimensions (W x H x D) 420 x 108 x 380mm
Net weight 7.5kg
Shipping weight 9.0kg
Power consumption (120 ~ 240V, 50/60Hz) 240VA
- God radio
- Kan brokobles
Selges for 500,-
8 ohm 160W (22dBW)
4 ohm 200W (23dBW)
2 ohm 250W (24dBW)
Net weight 7.5kg
