Moiz Audio
Butikk Mytek Liberty DAC II
D/a konverter
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Pris
Kr 15.200
Annonse beskrivelse
Annonse nummer: 237208
Mytek Liberty DAC II er den nye innstegsmodellen fra Mytek. Liberty DAC II har en oppgradert DAC chip ( ESS9038Pro) og lineær strømforsyning har nå blitt integrert. Lyden er åpen, gjennomsiktig og detaljert. Liberty DAC II leveres med en høykvalitets hodetelefonforsterker hvor ytelsen er 3 Watt.
DACen støtter PCM opp 32 bit / 384kHz, DSD opp til DSD512 og fullstendig utfolding av Master Quality Authentication (MQA) filer
Liberty DAC II Significant Design Features:
● 5 Digital inputs: AES/EBU x1, S/PDIF x2, Toslink/ADAT x1 - PCM up to 192KHz and up to DSD64 DoP; USB2 Class 2 x1 (OSX, Win 11, Linux driverless, all audio formats) - PCM up to 32-bit/768kHz, up to DSD256 native, MQA™, DXD.
● Analog outputs: 1 pair of balanced XLR; 1 pair of unbalanced RCA.
● Front panel LED indicators: active digital input; current bit-depth; MQA active; current sampling rate or DSD rate; volume level.
● Signal-to-noise ratio >128dB
● Hardware based 32-bit (w/192dB DR) dynamic volume control featuring 256 steps in 0.5dB increments that can also be controlled by (i) an included IR remote control, (ii) a connected computer via USB HID or (iii) a ROON core.
● Additional USB HID IR remote features include playback, pause and skip functions on Tidal, Spotify, Qobuz, Youtube, etc. players.
● Headphone amplifier: High current maximum output of 300mA/3.0 watts with the ability to effortlessly power any headphone, including those that are hard to drive.
● Overbuilt power supply includes automatic worldwide AC input voltage switching.
● Chassis: Black aluminum front panel finish.
● Dimensions (w x d x h): 5.5” x 8.8” x 1.74” / 140mm x 225mm x 44mm.
● Weight: 4.4lbs / 2.0Kg.
● Global Warranty: 2 years.
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moiz Audio
Torget karakterer
Vurderinger (119)
Andre annonser av Moiz Audio
