Selger en pent brukt senterhøyttaler fra Monitor Audio. Den er snart 5 år gammel og er opprinnelig kjøpt fra Hifi-huset. Ser ganske strøken ut for alderen å være.
System Format
3-Way
Frequency Response
40 Hz - 60 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
8 Ohms
Maximum SPL
113.8 dBA
Power Handling (RMS)
200 W
Recommended Amplifier Requirements
100 - 200 W
Bass Alignment
Sealed Cabinet
Crossover Frequency
L.F - M.F: 800 Hz
M.F - H.F: 2.3 kHz
Drive Unit Complement
2 x 6.5" RST bass/mid-range driver
1 x 4" RST mid-range driver
1 x C-CAM H.F ribbon transducer
External Dimensions (H x W x D)
254 x 581 x 333 mm
(10 x 227/8 x 131/8 inch)
Weight
18.9 kg (41.6 lbs)
System Format
3-Way
Frequency Response
40 Hz - 60 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
8 Ohms
Maximum SPL
113.8 dBA
200 W
100 - 200 W
Bass Alignment
Sealed Cabinet
Crossover Frequency
L.F - M.F: 800 Hz
M.F - H.F: 2.3 kHz
254 x 581 x 333 mm
Weight
18.9 kg (41.6 lbs)
