Lumin D2
Lumin er merket som satt streaming på tapeten og gjorde dett tilgjengelig for alle. Fantastisk lyd med markedets beste brukervennlighet, MQA,ROON,Spotify,Tidal, Qobuz,Airplay og Internettradio.
I tillegg så utvikles det hele tiden forbedringer som gjør at Lumin holder seg i forkant av utviklingen - og dette oppgraderes automatisk via appen.
Dette er produkter man skjelden ser på bruktmarkedet, og det er fordi man er fornøyd!
Lumin leverer produkter som passer inn i alle oppsett, og det gjør det uproblematisk å kjøpe. Lumin har streamere i alle prisklasser - fra 25000,- og opp til 100.000,- +
D2 Specification
DSD Support:
DSD128 5.6MHz, 1-bit
Analog Output Stage:
Wolfson WM8741 DAC chips, 1 chip per channel
Fully balanced layout with high-quality components
Power Supply:
Internal 100?240V AC auto-ranging
Physical:
Unit size: 300mm (W), 244mm (D), 60mm (H), 2.5kg
Box size: 470mm (W), 340mm (D), 170mm (H), 4.5kg
Specification for all LUMIN Music Players
Streaming Protocol:
UPnP AV protocol with audio streaming extension
Gapless Playback
On-Device Playlist
Supported Audio File Formats:
DSD Lossless:
DSF (DSD), DIFF (DSD), DoP (DSD)
PCM Lossless:
FLAC, Apple Lossless (ALAC), WAV, AIFF
Compressed (lossy) Audio:
MP3, AAC (in M4A container)
Supported Audio Sample Rates, Bit Depths, Number of Channels:
PCM, 44.1kHz - 384kHz, 16 - 32bit, Stereo
DSD, 2.8MHz, 5.6MHz, 1bit, Stereo
Upsampling rates & bit depths:
DSD upsampling option for all files up to 96kHz
Supported Control Devices:
Apple iPad (year 2014 or later). iOS 8.0 or later required. Full Retina Display support.
App Features:
High-resolution artwork. Artwork caching. AirPlay compatibility. Multiple-tag handling. ?Composer? tag support. Find & Filter. Tag browsing.
Input:
Ethernet Network 1000Base-T
USB storage, flash drive, USB hard disk (Single-partition FAT32, NTFS and EXT2/3 only)
Outputs:
Analog Audio:
XLR balanced, 4Vrms, pin 2 Hot
RCA unbalanced, 2Vrms
Digital Audio:
BNC SPDIF:
PCM 44.1kHz-192kHz, 16-24bit
DSD (DoP, DSD over PCM) 2.8MHz, 1bit
Finish:
Raw brushed aluminium
Black anodised aluminium
Other:
Firmware-upgradable for further features and enhancements
D2 Specification
DSD Support:
Power Supply:
Physical:
Streaming Protocol:
Gapless Playback
On-Device Playlist
DSD Lossless:
PCM Lossless:
App Features:
Input:
Outputs:
Analog Audio:
Digital Audio:
BNC SPDIF:
Finish:
Other:
