Flott eksemplar som er pakket opp og prøvd/demonstrert for kunde. Spiller magisk med en god preamp.
Ta kontakt for demo og tilbud
Ordinærpris: 27.000,-
Audiophiles will appreciate the detail and resolution from the ultra-wide 1.5 Hz to 70 kHz bandwidth. Professionals will love the abundance of effortless power. Characterized by a solid and taut low end with fully developed shimmer in the top extremes, Powerbloc2 is one of the most versatile reference grade amplifiers ever.
The benefits of multi-amplification are inarguable; lower intermodulaton, greater headroom and freedom from harmful clipping. Yet concerns over cost, bulk and complexity have prevented users from enjoying these substantial advantages. The Powerbloc2 can be used in pairs with Legacy Audio's DSP based processor/crossovers to raise system performance to a new level. They can also be used in pairs to bi-amp passive loudspeakers.
Numerous refinements to class D topologies in recent years have resulted in improvements that not only match the neutrality of other high end designs, but actually exceed typical performance parameters in several ways:
The Legacy Powerbloc2 provides serious power... for serious listening.
The Powerbloc is also available in a 4 channel version, the Powerbloc4.
Award-Winning Design
The Legacy Powerbloc2 is the recipient of both a Sound & Vision Magazine Top Pick Award and a "Thumbs Up" Award from Secrets of Home Theater & High Fidelity.
"All the power most will ever need, with the sound quality you want in a slim, cool-running package." - Dan Kumin, Sound & Vision
"The Powerbloc2 had finesse and muscle, imaging was excellent, and it had complete control of my speakers, allowing me to hear what they can do. If you are in the market for a two-channel sound system and you want these qualities in your sound system, give the Legacy Powerbloc2 a closer look and listen. Your speakers will thank you." - Jim Milton, Secrets of Home Theater & High Fidelity
Specifications
- High damping factor
- Low output impedance
- Wide bandwidth
- Huge dynamic range
Specifications
- Product Manual - Download Manual
- Power per side:325 watts per channel x 2 @ 8 ohms, 650 watts per channel x 2 @ 4 ohms
- Inputs:2 balanced XLR, 2 unbalanced RCA
- Outputs:2 pair gold plated safety approved five-way binding posts
- Damping Factor:1,000< 1kHz
- Voltage Gain:27.4 dB
- Dynamic Range:117 dB
- Peak Current:30 amps/channel
- THD:0.005% at rated output
- TIM:0.0045% at rated output
- Input Sensitivity:2.1 Volts to rated power
- Dimensions: 3" H x 17" W x 14" D
- Unit Weight:13 lbs
- Shipping Dimensions:9" H x 22" W x 18 D
- Shipping Weight:18 lbs
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
