roov
Leak Stereo 130 Solgt
Integrert forsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Hordaland
Pris
Kr 6.990
Kjøpt av
larsenroed
Annonse beskrivelse
Annonse nummer: 254057
Strøken Leak Stereo 130 i valnøtt
Ny i 2022.
Bilder er av aktuelt produkt.
Alt av tilbehør samt original emballasje.
Les mer her: https://www.stereofil.no/stereo/integrerte-forsterkere/leak-stereo-130
Hjemmeside: https://www.leakaudio.com/products/leak-stereo-130-integrated-amplifier
Spesifikasjoner
  • D/A Converter: ESS Sabre32 Reference ES9018K2M
  • Input Sampling Rates: Optical, Coaxial: 44.1kHz~192kHz;
  • USB: 44.1kHz~384kHz (PCM)/DSD64, DSD128, DSD256
  • Rated Output Power: 2 x 45W (8ohm)/2x65W (4ohm)
  • Total Harmonic Distortion: < 0.005% (30W, 8ohm)
  • Frequency Response: 20Hz-20kHz (+/-0.5dB)
  • Input Sensitivity: 480mV (RCA AUX IN); 4.1mV (phono MM)
  • Input Impedance: 10Kohm (AUX) ; 47Kohm //100pF (phono MM)
  • Signal to Noise Ratio (S/N): ≥108dB (A-weighted, ref.45W)
  • Pre Output Level: 4
  • Pre Output Total Harmonic Distortion (THD): < 0.003%
  • Pre Output Signal to Noise (S/N): >110dB (A-weighted)
  • Bluetooth Version: A2DP
  • Codec: aptX (priority), SBC
  • USB Input: 1 x USB (B-type)
  • Digital Audio Inputs: 2 x Optical TOSlink ,1 x RCA COAX
  • Digital Audio Outputs: 1 x Optical TOSlink ,1 x RCA COAX
  • Analog Inputs: 2 x RCA (AUX1, AUX2) ,1 x RCA (phono MM)
  • Analog Output: 1 x RCA (PRE OUT)
  • Power Requirement (Depends on your area): 220-240V ~ 50/60Hz 100-120V ~ 50/60Hz
  • Dimensions W x H x D (mm): 326 x 146 x 276 (Wood)
  • Carton Size W x H x D (mm): 475 x 248 x 450
  • Net Weight: 8.30kg (Walnut)
  • Gross Weight: 10.60kg (Walnut)
  • Finish: Walnut
Originalemballasje
Ja
Orig. kvittering
Nei
Forsendelse
Kan sendes
roov
Fersking
Torget karakterer
Vurderinger (23)
Andre annonser av roov
