Lampizator ble kjent for sine D/A convertere, og har stadig utviklet disse gjennom årene. De er kjent for å være "analoge", men med alle kvalitetene til en digital kilde. DAC’ene er i toppklassen, og har du en digital kilde som cd drev eller streamer så vil en Lampizator DAC hente maks ut av det digitale signalet.
Denne kommer i 4 former:
Ubalansert SE eller balansert, med eller uten volumkontroll for å kunne erstatte en forforsterker.
Prisene er:
Single ended, uten volum - 90.000,-
Single ended med volum - 120.000,-
Fullbalansert OG SE uten volum - 120.000,-
Fullbalansert OG SE med volum - 150.000,-
Lampizator DAC lages på bestilling etter dine ønsker - bestillingstid ca. 4 uker. Fargevalg osv avtales ved bestilling.
The first original Atlantic1 DAC was made 5 years ago, to the memory of Lukasz Fikus' sailing trip across the Atlantic ocean. It was meant to put in one attractive package as many features of the most desirable audiophile wish list - as possible. From early 2019 we redesigned the Atlantic, mainly to enable the last missing feature from that wish list - ability to roll (change) tubes. The use of octal base pinout, compatible with power tetrodes and pentodes, plus only one and common 6,3 V heater voltage, enabled us to offer tens of different tube types to be used alternatively. Hence the new name - TRP = Tube Rollers Paradise. Just one internet tube store offers 120 tube models compatible with Atlantic-3 TRP DAC. Add to it the multiplication of NOS brands etc. We tested TRP with circa 20 tube types, and frankly we haven't found one that plays bad.
Moving upwards from Amber and Baltic, you get the first DAC that doesn't use so called small signal tubes but instead - we use the overkill power tubes, acting like small signal. They are way off the typical operating points used in amplifiers, and that's why these tubes in our DAC are not stressed, not running out of steam, but instead acting with unheard-of authority, ease, grace and dynamics. The resulting sound character of this DAC is a whole notch better than obtainable from small tube. You owe it to yourself to hear what such pentode system can do. It would be like the first ride in a V8 car. There is - simply speaking - no going back.
The main features of this DAC are:
Tube based power supply, choke CLC filtering, copper output caps, (from November 2022 with name change to Atlantic3 you get engine ELEVEN with DSD512x , Balanced or Single ended - by order, possibility to add full preamp feature with remote control, display, and resistor ladders. Balanced configuration is truly balanced, not merely an SE circuit with phase doubler at the end. You get also analog preamp inputs, newest USB firmware for Linux and Windows, and as standard you get the fine EL34 or KT88 tetrodes that we can obtain from current production.
The standard top cover on Atlantic 3 TRP DAC is CHARCOAL BLACK (not copper as on the pictures)
Some facts about Atlantic 3 TRP:
Prisene er:
- 4 digital input types instead of 3
MAIN SPECS:
4 main variants - - Single Ended RCA , no preamp/volume
- Single Ended RCA , WITH preamp/volume
- Fully Balanced & Single Ended RCA , no preamp/volume
- Fully Balanced & Single Ended RCA , WITH preamp/volume
- New phenomenally musical engine of digital conversion called Engine Eleven
- New OLED display, no more LCD
- Software driven signal routing, no more relays
- Total muting to keep switching noises down
- Plays every digital file known
- no drivers needed for any computer operating system
- Volume control models have one analog input for analog sources (active input with tubes and volume)
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
