Får inn nye varer! førstemann til mølla!
PRE1 er en rørbasert forforsterker basert på E88cc trioden. PRE1 har fem analoge innganger og to variable utganger. Lydmessig har den en varm klangkarakter, som mange vil like.
Features:
Toroidal power transformer
Blue Velvet ALPS potentiometer
Special Audio Grade parts in every stage
No feedback design
SRSG® implementation
fine symmetry® implementation
Gold plated Teflon rca connectors
Gold plated tube sockets
Remote control
5mm Aluminum face panel with luxury painting
Five Years Guarantee
Specifications:
Power: 230/240 Vac 50Hz (1? fused)
Power consumption: 80 VA max
Frequency responce: +0-3dB, 5Hz to 200kHz
Distortion: 0.04% at 2V RMS output
Gain: 21dB
Signal to Noise ratio: 90dB
Maximum output: 14V RMS
Input impedance: 50K ohms
Output impedance: 900 ohm
Tube complement: 2x E88CC dual triode, (tube audio circuit, solid-state power supply)
Warm up time: 1 minute
Inputs: 5x line stereo (RCA connectors)
Preamp outputs: 2xline stereo
Available colors: Matt Black
Dimensions (WxHxD): 43x11x29 cm
Weight: 6 Kg
Features:
No feedback design
Remote control
Specifications:
Gain: 21dB
Weight: 6 Kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
