Nydelig innbytte eksemplar av Kuzma Stabi S PS + Kuzma 4 point 9 Arm og separat strømforsyning til salgs. Selges med 50% rabatt.
En eier. Kjøpt hos Mala Audio. Orginal emballasje og kvittering. Nypris 115000 kr +
malaaudio.no
malaaudio.no
hifiplus.com
Produktbeskrivelse
Stabi S PS er en pakke med Stabi S drivverk med separat PSU og leveres i mange kombinasjoner med ulike armer og pickuper. Ta kontakt med oss for ett godt pakketilbud.
Stabi S is our smallest turntable with a design approach normally found only in more expensive models. Its unique shape and construction of solid brass rods, provide an extremely rigid connection to platter, bearing and tonearm support. There is no flat plate to resonate and transmit vibrations, only solid brass rods 50mm in diameter. A second brass rod provides stability and the two are clamped together in a T shape. The motor is housed independently in its own bras tower which dampens vibration of the motor itself. A ground, flat belt provides drive from the motor pulley to the subplatter.
The bearing is of highly polished, fine grain carbon steel with a one point contact, while the bearing sleeve is of a resin/textile material which has excellent damping, non-resonant properties.
With a mat on top and rubber damping insert underneath, the sold aluminium platter provides a stable non-resonant platform for records.
An acrylic cover protects platter and tonearm while reflecting the turntable’s original shape. A 45 rpm adaptor is provided and is simply slipped over the 33 rpm pulley. The turntable can accommodate various tonearms by the use of different pre- cut brass plates and it allows for VTA adjustment on any tonearm mounted.
The whole turntable is supported by an optional high density plywood plate.
Spesifikasjoner
Mass 13 Kg
Platter mass 4 Kg ( since 2018 is supplied thicker platter- 30 mm)
Platter material Aluminium
Bearing type Pointed shaft with resin/textile material
Shaft diameter 10 mm
Drive Flat rubber belt
Chassis/Levelling Brass/ No
Turntable levelling No
Motors 1 pc AC
External power supply optional
Speeds 33,45 rpm
Armboard optional ( Kuzma arms fit directly)
VTA adjustment Yes
No. of tonearms 1 (+1 optional)
Max tonearm’s length 10” ( optional 12”)
Suspended No
Dimensions 400x300x170 mm
Finishes brass or black
Clamp Optional
Mat Yes
Lid Yes
Accessories Oil, Allen keys
Options SD- second arm kit,12” kit, extra platter kit(2.6 kg onkly for 20mm thicker platter),
Options Various armboards, outboard power supply,
Options Brass clamp ( 370 g), supporting platforms
Produktbeskrivelse
4Point 9 is shorter version of 4Point tonearm. Due its 9 inch lenght and lack of VTA tower makes this tonearm lighter and smaller thus capable of fitting on most suspendded turntables.
HIFI+ review: Jan 2018 #155: 4Point 9:The best tonearm ever?
HIFI + award 2017: best tonearm is 4Point 9
Spesifikasjoner
Effective lenght 229 mm
Arm mount distance 212 mm
Spindle to pivot distance 212 mm
Bearing type 4 pivot
Effective mass 13 g
Total mass 920 g
Offset angle 23 deg
VTA adjustment Yes
Azimuth Worm drive
Tube Conical
Bias Yes
Max cartridge mass 35 g
Damping No
Detachable headshell Yes
Arm mount Kuzma
Standard wiring Silver
Accessories Yes
Optional wiring Yes
Optional connectors XLR,5 Pin
Kuzma Stabi S PS
Kuzma 4 Point 9
Stabi S turntable reviews - Kuzma Professional Turntables, Tonearms and Accessories
Professional Turntables, Tonearms and Accessories.
www.kuzma.si
4Point tonearms reviews ( 9,11,14 inch) - Kuzma Professional Turntables, Tonearms and Accessories
www.kuzma.si
Kuzma Stabi S turntable, 4Point 9 tonearm, and CAR‑40 MC cartridge
There’s an established hierarchy in vinyl replay that is almost inviolate. The expenditure goes from top down; spend most money on the turntable, then the
Produktbeskrivelse
Spesifikasjoner
Mass 13 Kg
Motors 1 pc AC
Speeds 33,45 rpm
VTA adjustment Yes
Suspended No
Clamp Optional
Mat Yes
Lid Yes
Produktbeskrivelse
Spesifikasjoner
Effective mass 13 g
Total mass 920 g
Offset angle 23 deg
VTA adjustment Yes
Azimuth Worm drive
Tube Conical
Bias Yes
Damping No
Arm mount Kuzma
Accessories Yes
Optional wiring Yes
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
