En ubrukt Kiseki Blue NS (uåpnet vare) selges på vegne av kunde.
Listepris: NOK 22 300,-
Ønsket pris: NOK 12 500,-
MC Kiseki Blue N.S. – SPECIFICATIONS
Body: Aluminum alloy, 25mm long
Cantilever: Solid Boron Rod: 0.28 mm diameter
Stylus: 0,12 x 0,12 Nude line-contact diamond, mirror polished
Stylus tip radius: 5 x 120 µm
Vertical Tracking Angle (VTA): 20 degrees
Coil: pure iron coil
Weight: 10 grams
Output voltage: 0.44 mV at 5 cm/s
Internal impedance: 40 ohms
Frequency response: 20 – 25.000 Hz ± 1 dB
Channel balance: 0.4 dB
Channel Separation: 35 dB at 1 kHz
Tracking ability at 315 Hz at a tracking force of 2.4 grams: 80 µm
Dynamic Compliance: 16 µm/mN
Recommended loading: 400 ohms
Recommend tracking force: 1.8 – 2.6 grams
Weight: 10 grams
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
