Moiz Audio
Butikk Kinki Studio EX Series M-1 Int.
Integrert forsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Pris
Kr 33.000
Annonse beskrivelse
Annonse nummer: 227379
Hypen er sann!
The EX Series is tuned to reproduce sound quality with balance mid and smooth extension in both ends, high and low extension. The EX-M1 is fully modular, a dual mono design in a single chassis. Rich in tonal quality, details, dynamic, and high resolution. Silky smooth volume control thanks to the discrete R2R volume control, of which known for its precise and accurate volume adjustment with precision matched resistors.
R2R VOL CONTROL
Most amplifiers use a potentiometer for volume control. EX-M1 uses an advanced microprocessor-controlled, relay-based R2R steps attenuator. Ultra-precise 256 steps linear volume control allow you to fine adjust the volume for late-night-listening.
COST-NO-OBJECT
The EX-M1 uses extremely high cost 0.2µm gold-plated printed circuit board (PCB). From the perspective of PCBs, it is clear that the designer is well aware of the limitations on the fine contact area of the general circuit board, specifically increasing the soldered area at each solder joint and adding as much shielding as possible. It uses two 300VA UK made AMPLIMO transformers, one each for Left and Right channel power supplies, so that the power does not interfere with each other to improve the channel separation.
215Watts RMS into 8?
EX-M1 is one of the rare Integrated Amplifier that is able to provide such a good driving capability in its price range. 215W (8?), both channel driven, can literally drive anything you throw at it.
SOUND CHARACTERISTIC
Neutrality and musicality were the goals to achieve. Rich tonal quality, vivid sound imaging, details, high resolution and dynamic. The choice of the components, design, and tuning does just that.
It is the Kinki Studio gears' sound signature.
Frequency Response: 10-150kHz (±3dB)
THDN: 0.0232%; 0.006% (A-Weighted)
S/N Ratio: >103dB
Output Power: 215W (8?), Both channel driven
Damping Factor: 2000
Max Output Voltage: 55VAC
AC Power: 110/240VAC, 50/60Hz (Factory configure)
Input / Output
Input Sensitivity: 2.25Vrms - 3.6Vrms
Input Impedance: 50k?
Input Connector: RCA x 3, XLR x 1
Output: Speaker Binding Post 4mm L/R Channel
Dimension: 430W x 125H x 370D
Weight: 25KG
Moiz Audio
Torget karakterer
Vurderinger (112)
Andre annonser av Moiz Audio
