Selger en pent brukt Karan KA S 400 effektforsterker i sort farge. Utrolig lekker forsterker som spiller forrykende!
Ekte dual mono konstruksjon med en 1000va trafo per kanal. Dempefaktor høyere enn 6000.
Forsterkeren er i topp stand og selges med original embalasje og manual. Ny pris 126 000kr, selges for 49 999kr. Kjøpt ny i Norge høsten 2012. Kvittering medfølger.
Spesifikkasjoner:
* 8 ultra fast Sanken RET output power devices per channel, with a total current capability of 160 Amperes;
* 8 stages of voltage regulation;
* Current feedback topology, with no overall feedback and with only 0.03% Intermediation distortion (IMD) at rated power output into 8 Ohms;
* Each channel uses a 1.000 VA low noise toroidal transformer and 132.000 µF of total capacitance;
* Frequency response DC-300kHz +0, -3 dB;
* S/N ratio better than -112 dB at rated output into 8 Ohms;
* Damping factor better than 6,000:1 into 8 Ohms, 20Hz?20kHz;
* Pink noise power output of 420W/660W/1.200W into 8/4/2 Ohms;
* Input sensitivity: 2V
* Dimensions 500x240x480 mm (19.7?x8.7?x26?) WxHxD
* Dimensions in box 640x360x570 mm WxHxD
* Net weight 52 kg
* Btto weight 64 kg
http://www.karanacoustics.com/ka-s-400
Spesifikkasjoner:
* Net weight 52 kg
* Btto weight 64 kg
