Power, refinement, and innovation for large listening spaces
The new Utah 8 is the flagship model of Indiana Line's Utah series. It is designed to deliver dynamic, detailed, and natural sound in rooms larger than 25 m². This is a 3-way floorstanding speaker featuring a powerful 12-inch woofer, a 7” midrange driver with second-generation Dual-Wave suspension, and a 28 mm aluminum-magnesium tweeter with 3D-Guide waveguide.
The rigid and carefully finished cabinet integrates, for the first time, the brand’s exclusive DIRS (Damped Inner Reinforcement System) – an internal damping structure that eliminates unwanted vibrations and enhances low-frequency precision. Thanks to its twin down-firing bass-reflex ports, the Utah 8 offers high-end performance even at elevated volume levels, maintaining control and clarity at all times.
Main Features
Sound of Heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
Main Features
- 3-way floorstanding speaker with reinforced MDF cabinet
- 12” woofer with Tri-Wave suspension and profiled polypropylene cone
- 7” midrange driver with Curv cone and UHVC (underhung voice coil) motor
- 28 mm tweeter in aluminum-magnesium with 3D-Guide waveguide and EQ-Ring
- DIRS system for internal vibration damping
- Twin down-firing bass-reflex ports – 3 operating modes using supplied port plugs
- 3-way crossover with air-core inductors and polypropylene film capacitors
- Bi-wiring / bi-amping capable terminals
- Magnetically attached front grille included
- Frequency response: 30 Hz – 30,000 Hz
- Sensitivity: 93 dB (2.8 V / 1 m)
- Impedance: 4 – 8 ohms
- Recommended amplifier power: 30 – 240 W
- Dimensions (H × W × D): 700 (732 with feet) × 400 × 375 mm
- Weight: 27 kg
- Available finishes: Black, Wood
Sound of Heaven
Tlf:+47 464 29 861
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
