Ikeda IST-201 MC Step-Up Transformer.
Stereophile Product of the Year. Handmade in Japan
We listened to a lot of phono stages and it takes a lot for us to be impressed. This Ikeda does that brilliantly. Now being awarded Product of the Year, its a no brainer when you want a SUT… TA
The newly developed Step-Up transformer IST-201 is best suitable for low impedance 1ohm – 6ohm MC cartridges. These low impedance cartridges will be able to work at their full potential by virtue of this high quality MC transformer.
IST-201 is the ideal transformer with a lesser internal loss so that you will be able to enjoy a supreme sound in combination with IKEDA 9 series and our flagship KAI cartridges as well as other brands of low impedance cartridges.
The body of the transformer is made of high efficiency core materials and magnetic shielding technology using MU-Metal with a high shielding rate. In addition, the body of the transformer is embedded and perfectly shielded within the large shielded chassis with high electrical conductivity.
Specification
Model: MC cartridge step-up transformer
Frequency characteristic: 10Hz ~ 100KHz ∓ 0.6dB (3Ω/47kΩ)
Step-up ratio: 26dB
Channel balance: 0.1dB or less (1kHz)
Input impedance: 1Ω ~ 6Ω
Load impedance: 47kΩ or more
Channel separation: 90dB or more (1kHz)
Dimensions: 140mm (W) × 65mm (H) × 95mm (D)
46000 kr ny Pris.
Reviews
www.audiophilia.com
Specification
Step-up ratio: 26dB
46000 kr ny Pris.
Reviews
IKEDA IST-201 Step-Up Transformer — Audiophilia
It would be instructive to read my review of the first Step-Up Transformer I reviewed, the EAR MC4. I’ll use the same introductory paragraph for the IKEDA IST-201 review as the technology (not sound) is the same. I’m new to SUTs, better known as Step-Up Transformers, small passive boxes that en
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
