Helt ny og urørt Ikeda 9ts. Masse å finne om denne på nettet. https://www.audio-activity.com/ikeda-9ts-en.html.
Output Voltage:
0.35mVrms (1kHz 35.4mm/sec. at 45°peak)
Coil Impedance:
6.0 Ohms (1kHz)
Appropriate Stylus Force:
2.0 Grams ±0.2 Grams
Frequency Response:
10Hz – 45kHz
Channel Separation:
Over 27dB (1kHz)
Channel Balance:
Within 1.0dB (1kHz)
Stylus Chip:
Oval-shaped solid diamond
Cantilever:
Double layered duralumin pipe
Weight:
10 Grams
Veil pris hos norsk importør er 27500,-
Output Voltage:
Coil Impedance:
6.0 Ohms (1kHz)
Frequency Response:
10Hz – 45kHz
Channel Separation:
Over 27dB (1kHz)
Channel Balance:
Within 1.0dB (1kHz)
Stylus Chip:
Cantilever:
Weight:
10 Grams
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
