iFi Micro iUSB Power
Designed as part of a collaboration between iFi Micro and AMR (Abbingdon Music Research), this candybar brick sits between your computer and USB DAC or USB-S/SPDIF convertor. It doesn’t filter – it completely severs the power connection between your computer’s motherboard and USB device and then injects its own 5V feed. Digital audio data is allowed to travel freely.
Micro iLink USB-Spdif Converter
The iLink USB‐to‐SPDIF converter is iFi’s attempt to make the highest quality USB to SPDIF on the market. The goal is to give the signal transfer the optimal environment so that nothing gets lost or corrupted in the conversion. Rather than start with the converter chip, iFi went beyond and analysed the complete transmission/conversion process.
Gemini USB kabel
Gemini is the only USB cable of its kind that fully separates the power and the audio signal in two cables, netting grain- and edge-free music reproduction. Gemini's special geometry adheres to the 90-ohm impedance specification even better than the USB 2.0 standard. In addition, FINAL USB machined connectors provide stellar end-to-end shielding while custom-designed triple RF silencers provide the widest possible filter range without affecting the USB signal. Pair with the iFi Micro iUSB Power & Micro iLink for the Ultimate in USB Quality.
Nypris totalt 9500,-
Med original emballasje.
Selges helst samlet.
Gemini USB kabel
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
