En knakende god riaa med alle justeringsmuligheter i front for både MM og MC. Er Egentlig en preamp, men går som et kinderegg av riaa i lp spiller miljø worldwide.
. Gunmetal finish. Ikke strøken, men velholdt kontra alder.
Går for 8K internasjonalt. https://www.ebay.com/itm/1341385121...customid=435c62a4-bcb7-11ed-b3bc-643038333061
Connections
Specifications
Special Features
Se mine referanser
- Manufacturer: Hitachi
- Model: HCA-7500 II
- Type: Preamplifier
- Years of manufacture: 1980 - 1983
- Made in: Japan
- Color: Black, Silver, Titanium
- Remote control: No
- Power consumption: 8 watts
- Dimensions: 435 x 83 x 292 mm (WxHxD)
- Weight: 4.5 kg
- Original price approx.: 798 DM
Connections
- Number of inputs: 4
- PHONO MM: 25 mV (22, 47, 100 kOhm)
- PHONO MC : 0,1 - 2,5 mV (100 kOhm)
- TUNER, AUX : 150 mV (47 kOhm)
- TAPE : 150 mV (47 kOhm)
- Number of outputs: 3
- PRE OUT : 1 V (600 Ohm)
- TAPE REC OUT: 150 mV (600 Ohm)
- PHONES OUT: 70 mV (90 Ohm)
Specifications
- Frequency response:
- PHONO (RIAA): 20-20000 Hz (±0.2 dB).
- TUNER, AUX : 5- 100000 Hz (+0 / -1.5 dB)
- Distortion factor:
- PHONO: < 0.005% at REC OUT level 5 V.
- Signal-to-noise ratio:
- PHONO MM: 91 dB
- TAPE : 104 dB
- Tone control:
- Bass: ±8 dB (150 Hz, 100 Hz transition at 150 Hz, 300 Hz).
- Loudness: (when volume control is set to -30dB)
- +8 dB (150 Hz)
- +8 dB (10 kHz)
- Subsonic Filter: 15 Hz (6 dB/oct.)
- Mute: - 20 dB
Special Features
- Record selector switch
- Mono/stereo switch
- Phono MM & MC
Se mine referanser
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
