Selger min Hegel H300 i meget bra stand da jeg har gått over til annet oppsett.
Følger med 2 fjernkontroller.
Utrolig forsterker med god Dac. Har også HT bypass
Hentes i Hokksund
Output power: 250W + 250W in 8 ohms, 430W + 430W in 4 ohms
Minimum load: 2 ohms
Analog Inputs: 1 balanced (XLR), 3 unbalanced (RCA)
Fixed analog inputs: 1 unbalanced Home Theatre (RCA)
Digital Inputs: 2 coaxial S/PDIF, 2 optical S/PDIF, 1 USB
Line level output: Unbalanced Pre Out (RCA)
Digital outputs: 1 coaxial S/PDIF
Control inputs: IR direct input (3,5 mm jack), max 12V
Speaker outputs: One pair of heavy duty gold plated terminals
Input impedance: Balanced 10kohm, unbalanced 10kohm
Output impedance pre out: 1kohm
Frequency response: 5Hz-180kHz (+/- 3dB)
Signal to noise ratio: More than 100dB
Crosstalk: Less than -100dB
Distortion: Less than 0,005% @ 100W 8 ohms 1kHz
Intermodulation: Less than 0,01% (19kHz + 20kHz)
Damping factor: More than 1000 (main output stage)
Power Supply: 1000VA dual mono, 90 000uF capacitors
Output stage: 20 pcs 15A 150W high speed bipolar transistors
Power consumption: 60W in standby switched on
Dimensions/weight (ex feet): 12cm x 43cm x 38cm (HxWxD), weight 25kg
Hentes i Hokksund
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
