Et strøkent eksemplar av legendariske Esoterix UX 3 selges for kunde.
Selges kun kr 21500 / akseptabelt bud!
Kostet ca 70000 ny. Spiller SACD/CD/DVD audio/DVD video.
Oppgradert hos Upgrade Audio oktober 2009 for 2000 us-dollar + frakt + mva.
Et av verdens aller beste drivverk sitter i.
Construction & Design
A three-part chassis design is used to support the heavy VRDS-NEO mechanism and to prevent the electrical interference between each circuit. The mechanism is centered within the chassis for stability. The chassis is supported by three pinpoint feet (patent pending) made of quenched steel, allowing the unit to be mechanically isolated from its environment. Thick aluminum is used on the front panel, and 1.6mm-thick steel is used for the covers to block vibrations. The front panel is designed to be simple yet elegant, with a brushed finish. The illuminated buttons with lit peripheries, and other features all, contribute to the sense of quality found only in high-end audiophile equipment.
Kan sendes , men den veier ca 27 kg.
Innbytte mulig, men foretrekker rent salg.
Andre gode tilbud finner du her.
http://esoteric.teac.com/products/ux-3/
