Moet Audio
Butikk Eltax Vintage 15" PWR 1959 i demo
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 13.990
Annonse beskrivelse
Annonse nummer: 249390
Klassisk retrohøyttaler med 15" bass til en veldig god pris. 34 kg med klassisk godlyd med tung og kontant bass.
Dette er veldig mye lyd for pengene.
ELTAX MONITOR PWR 1959
3-ways Bass-reflex Speakers 250W 96db 30Hz-22kHz Vintage Walnut Design (Pair)
ELTAX MONITOR PWR 1959 Enceintes 3 Voies 250W 96db 30Hz-22kHz Design Vintage Noyer (La paire)
The Eltax Monitor PWR 1959 with their vintage look are inspired by the finest loudspeakers of the 70s. Two 25mm dome tweeters ensure the retransmission of a balanced and rich sound as well as deep and generous bass. This model highlights the bass thanks to their impactful and powerful transcription while remaining natural.
A 38 cm bass speaker
Its 38cm loudspeaker, whose membrane is made of cellulose pulp, makes it possible to move a large mass of air while combining rigidity and lightness. It can therefore go for very low frequencies while restoring the sound in a reactive and dynamic way. In addition, this loudspeaker is loaded with Bass-Reflex, which allows it to extend its response up to a frequency of 30Hz and deliver powerful, deep and realistic bass.
A medium of 16 cm and two treble domes for a balanced and precise rendering
Two 25mm diameter dome tweeters as well as a central warhead in a compression chamber allow a homogeneous and precise reproduction of high frequencies. It is the central ogive mechanically amplifying the output which allows this very clean diffusion of the treble. In addition, the midrange driver gives the Eltax Monitor MTR 1959 a rich and natural sound on the midrange.
A vintage walnut-effect design
The Eltax Monitor PWR 1959 adopt a robust cabinetwork with its reinforced MDF boxes elegantly reminiscent of the aesthetics of the 70s. Its dimensions of 51.8cm wide and 90cm high made them relatively impressive speakers. Technically speaking, there are also many internal reinforcements to limit and eliminate harmful vibrations. In addition, the inclined supports of the speakers optimize the phase and the perception of the different frequencies. The two vents opening on the front face of the speaker supporting the bass-reflex reduce the spacing of the speakers necessary with a rear wall and facilitate their placement in a room. Finally, the large section cables, the banana plugs and the forks are compatible with the screw terminals of the Eltax Monitor 1959 loudspeaker.
Technical characteristics
SPECIFICATIONS
Product typePassive speakers
System type3-way / Bass-Reflex (2x front vent)
Effective power30-250W
Bass-speaker (Woofer)Ø38cm, cellulose pulp membrane
Medium speakerØ16cm, cellulose pulp membrane
Tweeters2x Ø25mm, dome with central ogive and acoustic pavilion
Frequency response (±4dB)30Hz - 22kHz (+/- 3 dB)
Sensibility96dB
Impedance5-8Ω
GENERAL
Dimensions (LxPxH)518 x 900 x 385 mm
Net weight34kg (Unit)
ColorWalnut
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
