Moet Audio
Butikk Elipson HERITAGE XLS 11
Stativhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 19.990
Annonse beskrivelse
Annonse nummer: 249393
Retro stativ høyttaler ifra Franske Elipson. Rangert som best buy av the-ear. Elipson have done a fine job in voicing the XLS 11 and an even better one it bringing it to market at such a reasonable price.
Test: https://the-ear.net/review-hardware/elipson-heritage-xls-11/
This new speaker resolutely adopts a vintage aesthetic code while being even more compact, discreet and elegant. However, what really arouses the interest of this speaker is its exceptional musicality.
This 3-way model with very reduced dimensions, equipped with a front bass-reflex tuning, is equipped with a new 21 cm diameter cellulose bass driver, derived from the 30 cm Heritage XLS 15 model. The other drivers, for their part, are identical: a 55 mm diameter treated dome midrange, capable of covering nearly three octaves and a 22 mm diameter silk dome tweeter, derived from the famous tweeter equipping our flagship model of the Prestige Facet series.
A fine amplitude adjustment of 2 dB allows you to adjust the midrange and treble registers according to the listening room or the user's hearing preferences.
Added to this is the possibility of inserting an optional metal stand inclined by 5° ( Elipson Heritage XLS Stand 1 ) for perfect acoustic phasing, raising it by 22 cm in addition to this inclination.
Speed and control of the bass, definition and depth of the midrange, delicacy and extension of the high register characterize the sonic pleasure of this Elipson Heritage XLS 11 speaker.
TECHNICAL
  • Type: Compact speaker - 3 ways - Bass - reflex
  • Event : Flared - front panel - Tuning frequency: 37 Hz
  • Power : 130 W RMS
  • Bass-midrange : 210 mm cellulose pulp Medium: 55 mm treated dome
  • Tweeter : 22 mm silk dome
  • Divider filter - Fc : 850 & 5000 Hz - 12dB/12dB-12dB/18dB
  • Frequency response (+/- 3dB) : 45-25,000 Hz
  • Fine control of mid & treble levels on the front:
  • - 1 dB / 0 dB (Ref) / + 1 dB
  • Recommended power: 50 - 150 W
  • Sensitivity: 90 dB / 1W / 1m
  • Impedance: 6 Ohms (min 3 Ohms @2400 Hz)
DIMENSIONS
  • Dimensions: H × W × D: 560 × 320 × 270/278 mm
  • Weight: 17 kg (each)
CONDITIONING
  • Packaging dimensions: H x W x D: 715 x 455 x 415 mm
  • Gross weight: 20.5 kg
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
