Bygget rundt SABER 9018 chippen.
• THD < 0.002%
• S/NR > 120db
• Channel separation >114db
• Input : coax / optical/ AES_EBU / usb
• Sampling freq USB 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz (16 to 32 bit 2-channel PCM) 2.8224 MHz, 5.6448 MHz (1-bit 2-channel DSD)
• COAX PCM 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz (16 to 24 bit 2-channel PCM)
• Optical PCM 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz (16 to 24 bit 2-channel PCM)
• Freq response : 2hz - 80 Khz +/- 3db
• Dynamic range > 115db
• Output level control 0 to -80db
• Output Voltage RCA 3.8 Vrms / XLR 1.8 Vrms
• Trigg In : 5 to 20 V
• Trigg out : 5 or 12 V selectable
• Idle power : 1 W stand-by / 10 W idle
• Dimension : 420 * 390 * 100 mm
• Weight : 12Kg
• THD < 0.002%
• S/NR > 120db
• Weight : 12Kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
