Butikk Diptyque DP107 i demo
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 72.000
Annonse beskrivelse
Annonse nummer: 241801
Fenomenale magnestater som spiller over det størrelsen tilsier. De som har hørt de har blitt mektig imponert over disse. Oppleves som naturtro, detaljerte, organiske og gir et flott lydbilde. Anbefaler alle å oppleve disse! Ingen kjøpeplikt, men skal ikke se for at du faller for fristelsen... Dette er en av de mindre modellene.
https://www.moetaudio.com/produkt/hoyttalere-4/gulvstaende/dyptyque/diptyque-audio-dp107
This new Diptyque DP107 model was born after 10 years of research and development. They are based on technology and design of very famous DP77 with a top size of 30cm. They are composed of a bass-medium membrane of 0.198m² operating on our exclusive PPBM * technology and a ribbon tweeter with neodynium magnets of 45cm long. Its mechanical sandwich structure is extremely rigid and guarantees the absence of coloring sound. Their steel and oak stand resumes the design of the old ribbon microphones, it brings great rigidity to the set and the ability to adjust the tilt according to the listening point. This harmonious proportion panel is a very high quality speaker. Its transparency, its speed and the superb sound image it deploys in the listening space will seduce the greatest music lovers.
Choice of customizations: 160 colors RAL / printed textiles with your photos.
Specifications : Diptyque Audio
Type 2 ways
Sensibility 86db/1W/1m
Impedance 6 Ohms
Bandwidth 40 – 19000Hz
Power handling 150 W (recommended amplifier > 60 W)
Dimensions (height / width / depth) 1070x470x20 mm
Weight / with stand 15Kg / 22Kg
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
