Har spilt ca 200 timer etter service.
Vacuum tubes:
KT120 x 4 / 6550 x 2 / 12BH7 x 2 / ECC81 x 2
Power output: 2 x 90 Watts
THD.: Less than 1 % at all levels
Frequency response: 5 Hz to 100 kHz - 3 dB
Input sensitivity: 1,5 V for rated power
Input impedance: 100K ohms
Overall negative feedback: 17 dB
Output taps: 8 ohms, 4 ohms.
S/N ratio ( IHF-A ) More than 100 dB
Output polarity: Non-inverting
Power consumption: 600W
Mains voltage range: +/- 12 %
Dimensions (mm.) 430 (W) 190 (H) 390 (D)
Weight: 26 kg.
Må hentes Lillestrøm
Vacuum tubes:
Weight: 26 kg.
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Må hentes
