Anledning vårt åpnings-salg av butikk i Stavanger
Vi har denne interessante forsterker/streamer/dac'en inne. Låter bra til prisen. Her får du virkelig mye for pengene!
Ordinærpris: 16.500,-
N25AMP ER DEN MEST AVANSERTE ALT-I-ETT-STREAMEREN I VERDEN, MED EN KRAFTIG 150 WATTS FORSTERKER INNEBYGD, EN SABRE³² REFERENCE DAC-BRIKKE OG HØY YTELSE DUAL CORE ARM CORTEX A9-PROSESSOR, SOM KJØRER PÅ 1,0 GHZ. DEN ER DESIGNET FOR Å OPPFYLLE ALLE KRAVENE TIL DIGITAL MUSIKKAVSPILLING, OG HOLDER TRITT MED DAGENS DIGITALE VERDEN.
• Support for major music streaming services - Amazon Music, HighResAudio, TIDAL, TIDAL MQA, Deezer, Qobuz, Spotify Connect, Napster and Internet Radio(Airable)
• Replaygain function to normalize loudness for individual songs or albums • MultiRoom function (Group Play)• Spotify Connect and Apple Airplay• Support for various file formats including MQA, DSD(64/128/256),
DXD(24Bit/352.8Khz), PCM signal up to 32Bit/384Khz including 24Bit/192Khz WAV/FLAC and a full range hi-res audio file formats.
• High connectivity• Versatile network functions such as UPnP Server/Client/Renderer,
Samba Server/Client(Network File Server/Client) are supported
• Support as a certified 'Roon Ready' end point• Multiple control methods with customized remote control App(NOVATRON
MusicX NEO) for iOS and Android, desktop PC(Windows, Mac), IR remote control and well-organized functional keys on the device fro
• Equipped with a high-performance dual core ARM Cortex A9 processor
running at 1.0Ghz
• Combined with 150 watts powerful class D amplifier built-in• ESS ES9018K2M Sabre32 Reference DAC chip for D-A conversion
• USB Audio Class 2.0 output for connection to external USB DACs• Isolated power supply circuit design, separate for digital and analogue
sections, to remove electrical noise
• 4.6” TFT LCD screen (800 x 320 pixels) for intuitive GUI• DAB+/FM tuner built-in• HDMI eARC input built-in• HDMI output for connecting external screens, such as a TV as the GUI
screen, or for audio signal output
• Bluetooth receiver built-in, with support for SBC, AAC, aptX, aptX LL,
aptX HD
• USB Audio Class 2.0 input• High quality analogue output terminals• Digital output (1 x Coaxial, 1 x Toslink)• Digital input (1 x Coaxial, 1 x Toslink) • USB 3.0 high speed host port x2, on the rear panel• USB 2.0 host port x1, on the front panel• Giga Fast Ethernet(10/100/1000Mbps) built-in• Five (5) custom keys on the front panel for DAB+ or FM radio presets• Precisely CNC-machined aluminum front panel and robust rigid steel
chassis
running at 1.0Ghz
aptX HD
chassis
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
