Selger en Clones Audio Sheva Dac som jeg kjøpte i 2014. Har orginal koffort og kvittering. Nypirs ca 18000 kr-
Er åpen for bud
www.monoandstereo.com
Funjoe of CLONES Audio just send in great news about new SHEVA DAC. SHEVA DAC is a reference class DAC of CLONES audio. ES9018 based D/A Converter with input source selection brings the widest PCM and DSD supports.
Stay tuned for the exclusive first impression in February at the Mono & Stereo following with the full blown review.
• Available in silver or black finish
• Digital Inputs: AES/EBU, S/PDIF, BNC,Toslink, I2S and USB
• 2 stereo analog outputs, one on XLR one on RCA
• 100steps fine setting via rotary encoder (digital domain) control main output
Frontpanel controls:
• Dot Matrix display for display of sampling rate, input source, audio level, filter type
• Rotary encoder with push switch
Special features:
• DSD 64/128 and DXD (384KHz 24bit PCM) compatible
• Ultra-Low Phase Noise Femto Master Clock
• Remarkable power supply has separate torroidal transformers for Analog and Digital section.
Sampling rates:
• AES/EBU, COAX, OPT up to 192kHz
• USB/I2S: PCM 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384kHz; DSD64, DSD128
Dimensions:240(w)x100(h)x210(d)mm
Weight: 6.7kg
Er åpen for bud
CLONES Audio SHEVA DAC review
Mono & Stereo High-End Audio Magazine: Magico - Nagra - Tidal Audio - Wilson Audio - MSB - Totaldac - Living Voice - Taiko Audio - Aries Cerat -Thrax
Special features:
Sampling rates:
Weight: 6.7kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Avtales nærmere
