Fin Chord 2Qute selges grunnet oppgradering.
Kan sendes i orignal emballasje.
Produktinfo:
chordelectronics.co.uk
Tester:
www.whathifi.com
www.13thnote.net
This is a terrific DAC that is very simple to use and has tremendous sound quality and would be recommended for many HiFi’s if you want to upgrade your existing DAC. If you think that simple looking but well made DACs in very small boxes can’t keep up with converters in much bigger HiFi cases, then you will miss out on what the 2Qute has to offer to your detriment. The 2Qute is so capable that it can fit into a range of different priced audiophile quality HiFi systems and is very much worth checking out. I’m even surprised it’s referred to as an entry level DAC by Chord, because this isn’t really typical entry level performance. It is particularly recommended where your speakers and amplification provide good resolving power but the DACs in your sources are old and in need of an upgrade.
Produktinfo:
2Qute
Tester:
Home review
Best DAC £500-£1000, Awards 2017. Chord has struck again with this fantastic and colourful DAC...
Chord Electronics 2Qute DAC
FPGA Digital to Analogue Converter (DAC) If you were to look at the 2Qute from a distance it would be easy to believe that its quality is not up to much, given its somewhat simple and
- Originalemballasje
- Ja
- Forsendelse
- Kan sendes
