Endpoint Audio
Butikk Bricasti M3 DAC, med streamer. Demomodell under 1/2 pris Solgt
D/a konverter
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 30.000
Kjøpt av
bevisfrond
Annonse beskrivelse
Annonse nummer: 236884
M3 med siste MDx oppdatering og innebygget streamerkort som er ROON read. Dette er en særdeles god DAC, som også kan brukes som forforsterker i et digitalt oppsett.
Native DSD - Analog volumkontrol.
Powerful Architecture
The M3 utilizes two independent linear power supplies for the analog and digital processing to insure low noise and superior isolation. A newly designed chassis made from robust CNC milled aluminum in sections insures superior thermal characteristics, excellent vibrational damping and shielding from RF.
Re-creating sound is an art and a science
The M3’s digital design employs precision DDS clocking that lowers jitter to extremely low levels, insuring a pure digital signal path without the use sample of rate converters, this combined with superior digital filter design, and Native DSD conversion yields a state of the art digital audio path. The M3’s high speed low distortion analog path features a bypass-able preamp class analog level control allowing the M3 to be used to drive power amps directly, with no bit loss for optimal analog performance.
Nypris er 72000,-
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (37)
Andre annonser av Endpoint Audio
