Moiz Audio
Butikk BOTW P&P ECO 15V - 16V Lineær PSU Solgt
Denne annonsen er utgått.
Løse komponenter
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Pris
Kr 2.995
Kjøpt av
Norcane
Annonse beskrivelse
Annonse nummer: 181608
Oppgraderte High End PSU passer perfekt med Auralic streamere, sjekk ut listen over komponenter som kan oppgraderes
BEST OF TWO WORLDS POWER & PRECISION ECO
The 15V - 16V BOTW P&P ECO is the upgrade solution for all your audio devices, that run on 15 or 16 Volt.
Compatibility List Link
The ?Best of Two Worlds Power & Precision ECO? audio upgrade (BOTW P&P ECO) is the successor of our ?Best of Two Worlds Solutions? audio upgrade (BOTWS). This new upgrade product combines power, precision and efficiency in an unique innovative manner. The BOTW P&P ECO is the best choice for every audiophile.
With the BOTW P&P ECO audio upgrade the purification of the current starts immediately there where the polluted current enters the upgrade. A dual stage mains filter and an earth line choke clean the current from high frequency pollution before the current reaches the transformer. The transformer is a custom-made audio grade transformer with electrostatic shielding.
The electronic design is innovative: it gets 50% more output out of the used electronics and consumes even up to 35% less energy than a conventional design. The BOTW P&P ECO audio upgrade concept is so efficient that it consumes only a few Euros a year more than the standard supplied high efficient, but also highly polluting switch mode adapter.
Finally, at the end of the DC cable the unique split current system has been placed. The electronic design and components used in this SBooster-version differ from the design of the SBooster Single Unit. The power supply of the BOTW P&P ECO audio upgrade provides the split current system with powerful and clean power, so the electronics can do their job profoundly, which is to buffer the power so that the power supply becomes very fast and to filter one last time the voltage and current before they enter the audio device.
This unique upgrade power supply with its large headroom delivers at all times sufficient clean power to the audio device to ensure a stable and continuous performance of the internal processes of the audio device in order to get the best performance out of the audio device.
This combination of power and precision results in ?easy? music, a perfect soundstage and a natural detailed sound.
Product highlights:
50% more output current;
Power saving design;
2 characteristics in 1 product:
Power for high current demanding equipment;
Precision for noise sensitive equipment;
2 selectable output voltages;
1 accessory setting;
Safety approvals;
IEC 14 power inlet for High-end mains cables;
High performance dual stage mains filter;
Earth line choke;
Overvoltage protection;
Custom made high efficient audio grade transformer;
High quality polypropylene film capacitors;
Improved no-noise SBooster split current system.
Moiz Audio
Torget karakterer
Vurderinger (123)
Andre annonser av Moiz Audio
