Vi tilbyr nå high-End lineære PSU fra Sbooster. kompatibel med de fleste DC baserte lydprodukter f.eks Mytek Brooklyn,SOTM sms-200
The BOTW P&P ECO 12V - 13.2V is the upgrade solution for all your audio devices, that run on 12V or 13.2V
The Best of Two World Power & Precision ECO is the successor of our Best of Two Worlds Solution upgrade. For the BOTW P&P ECO we have applied a large number of innovative techniques in order to improve the sound quality of your audio device to a much higher level compared to a conventional linear audio power supply.
Compatibility list
https://www.sbooster.com/botw-pp-eco-12v-132v/
Specifications:
Output Voltage & Current
12V - 3A
12.5V - 2.5A
13.2V - 2.25A
Mains Voltage*
100 Volt AC 50/60Hz
110 Volt AC 50/60Hz
115 Volt AC 50/60Hz
120 Volt AC 50/60Hz
220 Volt AC 50/60Hz
230 Volt AC 50/60Hz
240 Volt AC 50/60Hz
Transformer
50VA audio grade toroidal with electrostatic shielding
Mains filter
High performance dual stage mains filter with earth line choke
Rectifier bridge
Power Schottky barrier rectifiers
Bulk capacitors
5 x Nichicon 4700µF + 1 x 5600µF + 1 Rubycon 330µF Low Impedance High Ripple Current Capacitors
Regulator
High-current ultra fast transient response LDO with external high precision shunt reference circuit
Filter capacitors
Non inductive polypropylene film capacitors
DC power cord
95cm 16 AWG spiral shielded, with integrated SBooster and interchangeable DC plug
Mains cable
Stock supplied
Size and Weight
Dimension: 240*130*75mm 1.85Kg
Safety approvals
CE/GS/CCC/KC/CTUVUS/FCC/PSB IEC60065 standard
Warranty
24 Months
Compatibility list
Specifications:
12V - 3A
12.5V - 2.5A
13.2V - 2.25A
Mains Voltage*
100 Volt AC 50/60Hz
110 Volt AC 50/60Hz
115 Volt AC 50/60Hz
120 Volt AC 50/60Hz
220 Volt AC 50/60Hz
230 Volt AC 50/60Hz
240 Volt AC 50/60Hz
Transformer
Mains filter
Rectifier bridge
Bulk capacitors
Regulator
Filter capacitors
DC power cord
Mains cable
Stock supplied
Size and Weight
Safety approvals
Warranty
24 Months
