Nye godsaker skal inn og jeg ‘gir’ bort denne til pølsepris!!
Nyprisen er 26-28k. Du får den i dag for 10k!!!!!
Ruby Z Open Air - 0,35 m V.
"The Benz Micro Ruby is truly a gem. And a real ruby is at the core of this hand-made pickups.
The windings of the coil can be applied to a ruby plate, which has generated this top-ideal electrical system and mechanical properties.
The Ruby is characterized by its tremendous ease of both the quietest passages, as well as the most brutal rough dynamics.
It is one of the absolute peak of Albert Lukascheks work and shares in the core technology with its SLR brothers and LP-S.
Thanks to the support system used in aluminum reaches the open system, weighs only 7.4 grams so it appears extremely flexible in combination with different tonearms on the market. And who also still look hard enough you can even see the red glow of the ruby."
Kan sendes eller hentes i Ski.
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
